10.3.3 Update - Battery Icon
  1. mark.aranha
    Donut Jun 10, 2020
    mark.aranha , Jun 10, 2020 :
    I received the 10.3.3 Oxygen update on my OP7 recently and it has changed the previously clean battery icon.
    Where it was earlier perfect- a simple opaque bar - There is now a plus sign within a border and an orange colour inside.
    The result is messy and makes the battery indicator quite unclear.
    Is there a way to go back to the previous battery icon?
    Thanks for reading!
  2. harshil1903
    Jelly Bean Jun 10, 2020
    harshil1903 , via OnePlus 7T , Jun 10, 2020 :
    It's because you've turned on battery saver. Turn it off and you'll see a clearer battery icon. Though you can't go back to old icons, unless you downgrade.
    AswinKumarT likes this.
  3. mark.aranha
    Donut Jun 10, 2020
    Thanks Harshil.
    I always keep the battery saver on so I guess I'm stuck with this. 🤦‍♂️🤦‍♂️🤦‍♂️
    What's worse...
    The battery at 9% looks totally healthy. No red indicator unless I turn off the battery saver!
    The Oxygen developers need to rethink their design.
  4. harshil1903
    It's because there aren't enough pixel to show 9 percent area of that small icon. Otherwise they'd be orange in colour to. Like if you turn on battery saver at 100 percent, you'll see orange colour filled icon.
  5. mark.aranha
    Donut Jun 10, 2020
    My point is that I would rather it just be the regular colour (white) as in 10.3.2
    I don't want any other colours except to indicate low battery. That was a perfectly good status bar. I don't know why this needed to be done. OnePlus is losing its touch with design.
  6. harshil1903
    You could always send a feedback regarding it.
  7. mark.aranha
    Donut Jun 10, 2020
    I have, under Suggestions
    harshil1903 likes this.
  8. Bashiq Ali
    Froyo Jun 11, 2020
    Bashiq Ali , Jun 11, 2020 :
    make it circle icon then it will look better
  9. mark.aranha
    Donut Jun 11, 2020
    mark.aranha , Jun 11, 2020 :
    Thanks, Bashiq. I have moved to the circle icon. The orange colour is still unsettling (maybe this is what they meant by 'never settle').
