12
12.1-YOG7DAS2K1 battery life worst then ever
  1. saikrishna235
    Honeycomb Jan 13, 2016
    saikrishna235 , Jan 13, 2016 :
    Factory reset is the only solution to this problem. I did it and now I'm getting good battery life.
    #61
  2. jdgasser
    Gingerbread Jan 13, 2016
    jdgasser , Jan 13, 2016 :
    yes
    i've accidentally made a factory reset, and since the battery life is come back to a "normal" average.
    #62
    saikrishna235 likes this.
  3. Bastes
    Cupcake Jan 13, 2016
    Bastes , Jan 13, 2016 :
    Same here, since that upgrade, the battery drains very, very, very fast. Has OnePlus said anything about releasing a fix?...
    #63
  4. Dolphine
    Eclair Jan 13, 2016
    Dolphine , Jan 13, 2016 :
    You mean CM said anything about releasing a fix?... ;)
    #64
    jstepa likes this.
  5. deeceeds
    Froyo Jan 13, 2016
    deeceeds , Jan 13, 2016 :
    what is the quickest and safest way to factory reset without data loss to get rid of the batery drain issue... hard one or soft one?
    #65
  6. jerov
    jerov , Jan 13, 2016 :
    Strangly, and without changing anything, today I have a normal battery consumption : about 20% are gone in 5hours of light usage (but WiFi and 4g activated, everything sync ...).
    I didn't do any Factory reset ...
    Strange ...Wait & see for next days !
    #66
  7. dr0gu3d
    Froyo Jan 13, 2016
    #67
  8. amardeep2006
    amardeep2006 , Jan 13, 2016 :
    I was also facing crazy battery drain . Tried following
    1. Uninstalling Cortana
    2. Disabled per app battery profiling
    but none of them was effective.
    Then i let battery fully drain, cleared battery history and left it connected to charger overnight .
    Finally today it seems to have improved significantly .
    Android OS and system are behaving bit sane. Hoping this to be just battery calibration issue which settle own it own with few more charge cycles. Screenshot_2016-01-13-21-02-48.png
    #68
    jerov likes this.
  9. pro100pk2
    #69
  10. thomasfogh
    Cupcake Jan 14, 2016
    thomasfogh , Jan 14, 2016 :
    My battery doesn't last 24 hours since upgrading to YOG7DAS2K1. Before it easily lasted +3 days. I can see from the battery statistics that the phone is awake all the time.
    #70
  11. 1111007
    1111007 , Jan 14, 2016 :
    Wait for an update or switch to cm13 nightly
    #71
  12. ameyacooldude
    ameyacooldude , Jan 14, 2016 :
    I've flashed the cm12.1.1 - YOG7DAS2K1 zip with quite a but of trouble. It is good but it seems to be missing the "ROOT ACCESS" option inside developer settings. Some more users seem to have the same issue. Please help if anyone knows the fix. I need root permission & Iam not sure what to do.
    #72
  13. jerov
    Cupcake Jan 15, 2016
    jerov , Jan 15, 2016 :
    As amardeep2006 I also think about a battery history and/or a battery calibration issue....
    After a full battery drain (phone turning off by itself when reaching 0% battery), a new complete charge and the issue seems now to be gone ...
    #73
  14. jdgasser
    Gingerbread Jan 15, 2016
    jdgasser , Jan 15, 2016 :
    i've switched to cm13 nigthly, and the battery life is good. but not better than the reset i've done 2 days before on cm12.1
    however, when i use a charger which is less than 2A (for exemple 1A or 1.5A) the charging time is very long. worst, when i'm using my OPO in my car with waze, the battery is emptying despite the car charger (1.5A).
    when i plug my OPO on my PC or laptop, and i let the screen on, the battery don't charge ...
    it's unbelievable :(
    apart this "detail", i like this rom :)
    #74
  15. ppp999
    ppp999 , Jan 15, 2016 :
    Since this update, the "Cyanogen Account" app and the "Android OS" are the most wasting battery life..
    Any fix for that?
    #75
  16. palatinius
    Cupcake Jan 22, 2016
    palatinius , Jan 22, 2016 :
    Am facing the same problem. After recharge 15 % off in no time. Totally strange behaviour.
    #76
  17. Oritsuro
    Honeycomb Jan 22, 2016
    Oritsuro , Jan 22, 2016 :
    Me too -> the only solution i found was, downgrade to PAS3.
    #77
  18. palatinius
    Sounds interesting. How do I do that??
    #78
  19. jamdutch
    Eclair Jan 25, 2016
    #79
  20. hramost
    Cupcake Feb 29, 2016
    hramost , Feb 29, 2016 :
    I was experiencing the same battery issue. I did the battery calibration thing and used amplify and greenify but nothing happened. Then I noticed the Google play background mobile data usage at 200mb over the last month!! Was using data despite settings restricting app updates over mobile networks. So I just restricted the background data usage and after two days the battery drain is gone. I'm now at 75% after 6 hours of moderate use, with 16 hours left... I suggest you check apps that are using too much data and restrict if necessary.
    #80
