3
12.1-YOG7DAS2K1 ready for deploy ...
  1. arjanvlek
    Honeycomb Dec 30, 2015
    #61
  2. trupen
    Gingerbread Dec 30, 2015
    trupen , Dec 30, 2015 :
    Waiting for full zip
    #62
  3. arjanvlek
    arjanvlek , Dec 30, 2015 :
    @trupen
    Full zip only comes when incremental roll out is at 100% (2-3 weeks) :(
    That's the new Cyanogen OTA process...
    #63
  4. trupen
    K thanks will wait
    #64
  5. e.dewaal
    Eclair Dec 30, 2015
    e.dewaal , Dec 30, 2015 :
    I have the same issue, running on 3jl, but i'm using twrp. See screenshot
    #65
  6. gewoon_emile
    Froyo Dec 30, 2015
    gewoon_emile , Dec 30, 2015 :
    Incremental updates can only be flashed with cyanogen recovery.
    #66
  7. Nixing
    Donut Dec 30, 2015
    #67
  8. ThomasBaer
    Froyo Dec 30, 2015
    #68
  9. LCOSTA17
    #69
  10. arjanvlek
    It's the 12.1.1. I have corrected this, so if you try now you'll see that you're definitely up to date!
    #70
  11. tomsliwowski
    tomsliwowski , Dec 30, 2015 :
    Has anyone successfully flashed this on a rooted phone? I'm getting a fingerprint error when flashing via Cyanogen Recovery. It thinks I'm running YOG4PAS2QL but my Cyanogen OS version in About phone says YOG4PAS3JL
    #71
  12. bmark240
    Ice Cream Sandwich Dec 30, 2015
    bmark240 , Dec 30, 2015 :
    Better wait until full zip is released. The incremental releases always seem rubbish & incompatible unless you unroot.
    #72
  13. arjanvlek
    You can't flash on rooted phone because it checks if the file system has been remounted as r/w. You'll need to cleanly flash YOG4PAS3JL and then update to YOG7DAS2K1.
    #73
    Mrtax and bramdegroot like this.
  14. Omkar.Narvekar
    #74
  15. CasperTFG
    KitKat Dec 30, 2015
    CasperTFG , Dec 30, 2015 :
    My money is end of January.
    #75
    mr.ignor likes this.
  16. CasperTFG
    KitKat Dec 30, 2015
    This.
    Remove that dialer crap. Bring Google's back.
    #76
    mrcndr82 likes this.
  17. thenicologix
    #77
  18. delpinsky
    delpinsky , Dec 30, 2015 :
    How about the so long promised Camera2 API and HAL v3 porting on the OnePlus One?
    I will never install CyanogenOS unless they will add those features.
    #78
  19. PhiliPdB
    Eclair Dec 30, 2015
    #79
  20. inroma
    inroma , Dec 30, 2015 :
    I like the new feature that shows you which app make the little notification on the bottom of the screen (it adds the app icon on the top left corner) : IMG_20151230_162149.jpg
    Me I had root so I dirty flashed 3JL that I already had so the root was removed and then I flashed the Incremental.
    #80
    doekus and tomsliwowski like this.
