3
12.1-YOG7DAS2K1 ready for deploy ...
  1. rodrigommartins
    Froyo Dec 30, 2015
    #81
  2. PhiliPdB
    Eclair Dec 30, 2015
    PhiliPdB , Dec 30, 2015 :
    Thanks
    #82
  3. inroma
    Honeycomb Dec 30, 2015
    inroma , Dec 30, 2015 :
    They also changed the design of the bars on the lockscreen when you play a song (new style, different colors) :
    #83
    xythiii likes this.
  4. thenicologix
    Gingerbread Dec 30, 2015
    thenicologix , Dec 30, 2015 :
    And the camera app design changed a little. I'm not sure but did the 4k DCI option disappear in this update or even a fee updates before? I only noticed that after this one
    #84
  5. nikhiltikare
    Cupcake Dec 30, 2015
    #85
  6. ilbarone87
    #86
  7. lazloinsf
    Froyo Dec 30, 2015
    lazloinsf , Dec 30, 2015 :
    Stock recovery install went just fine -- seems to have fixed the NavButtons changing to a different theme set each reboot bug -- did de-associate phone app icon from app, had to remove icon then re-place it from app drawer (and it's still TrueCaller, Ugh!!!) -- will have to go through startup list and turn off everything it probably turned back on again -- will also have to observe battery use as it usually takes some number of days / reboots to settle back down to something reasonable from Update-InstaDrain ....
    #87
  8. kk22
    Gingerbread Dec 31, 2015
    kk22 , Dec 31, 2015 :
    Just installed the incremental OTA. Stock recovery. All went fine. Will observe to check for any issues.
    #88
  9. supernova5432
    Froyo Dec 31, 2015
    supernova5432 , Dec 31, 2015 :
    hi, I've just installed 12.1-YOG4PAS3JL on my OPO using OTA (after many times incremental updates).
    my short review (using Google Launcher Now):
    - battery drain
    - messaging application for SMS not running well (very slow and almost cant view the history or detail messages).
    - sometimes after deleting running apps from recent apps, we can not go back to home screen again (blank screen).
    - blocked caller list can not show the contact names only display the phone numbers.
    - still reviewing.
    expecting new updates to solve those issues and I think those issues should not exist anymore cause its a basic needs where that bugs is not exist on previous version .
    FYI,
    my OPO isn't Rooted aka still virgin (original version).
    #89
  10. lazloinsf
    Froyo Dec 31, 2015
    lazloinsf , Dec 31, 2015 :
    battery drain IS TO BE EXPECTED!!!!! after update -- it takes several days / reboots for system to reorient / recalibrate itself -- I am now at 13% for Android System process so it is working hard on something, should be back to its usual 1% in a few ... Update-InstaDrain is a "well known phenomenon"
    #90
  11. supernova5432
    Froyo Dec 31, 2015
    thanks a lot @lazloinsf.
    worst than that, my WhatsApp getting error. could not search my recent contacts in WA.
    #91
  12. ganesh_mazzumdar
    Cupcake Dec 31, 2015
    #92
  13. Joachim Konrad
    Eclair Dec 31, 2015
    Joachim Konrad , Dec 31, 2015 :
    I have no more profiles in the starting menu after the update :(
    Where is the right place for asking a solution?
    #93
  14. supernova5432
    Froyo Dec 31, 2015
    WhatsApp problem solved --> unsintall WA and download again from PlayStore.
    #94
  15. cooldude17
    cooldude17 , Dec 31, 2015 :
    what music app are you using?
    my lockscreen doesnt have that widget for my music app. know of any way i can get it?
    #95
  16. cosmic
    Ice Cream Sandwich Dec 31, 2015
    cosmic , Dec 31, 2015 :
    No - the incremental will not flash via twrp; have to wait for the full image to use with twrp
    #96
  17. Alecksander
    #97
  18. MMWolverine
    Eclair Dec 31, 2015
    MMWolverine , Dec 31, 2015 :
    OTA can be flashed with stock recovery, but you first need to reflash YOG4PAS3JL rom, so that it's not rooted (system r/w) and has the stock kernel.
    #98
  19. inroma
    Honeycomb Dec 31, 2015
    inroma , Dec 31, 2015 :
    I'm using PowerAmp, maybe in your music app settings ?
    #99
  20. Alecksander
    Alecksander , Dec 31, 2015 :
    Reflashed 3JL then flash update but nothong
