12 hour not converting in Screen lock via OnePlus Nord
  1. Kaysar_Sarwar
    Cupcake Jan 19, 2022
  2. hbk1402
    Beta Tester of the Year Award 2021 Jan 19, 2022
    hbk1402 , Jan 19, 2022 :
    Strange, for me by default the ambient clock on lock screen shows 12 hrs format.
    Try using any other clock from app store.
    Shailender Sharma likes this.
  3. Himanshu.Behera
    Jelly Bean Jan 19, 2022
    Himanshu.Behera , via OnePlus Nord , Jan 19, 2022 :
    Visit settings - search Time Format. This will show you the option for time format. Check there if the option for 24hrs format is enabled. If so disable it.
    This will give you the 12hrs format on the home screen as well as on the lock screen.
  4. harshit.b.
    Jelly Bean Jan 20, 2022
    harshit.b. , via OnePlus 6 , Jan 20, 2022 :
    Had the same issue on my op 6 even when I had the 24 hour toggle turned off. Switching the 24 hour toggle on and off again fixed the issue for me.
