2meter dash cable
  1. Shery4life Honeycomb Jun 24, 2019
    Shery4life, Jun 24, 2019 :
    How do I request for a longer cable. Currently the cable that comes with the phone is only 1 meter. And I would like it if oneplus will make 2 meter dash/warp cable for oneplus devices
  2. Nick 59 Lollipop Jun 24, 2019
    Nick 59, Jun 24, 2019 :
    It is a real problem. 1m is simply too short most of the time and it seems most other cables won't work because Oneplus uses an extra pin for Dash/Warp.
    However, I found a recommendation for this on Reddit:
    https://www.amazon.com/dp/B07SHDS3P...&pd_rd_r=2243f4b6-96b0-11e9-aaf1-95771a143f2b
    Apparently works fine but I don't have my own...yet.
    buntycubal, Shery4life and keithnyc like this.
  3. keithnyc Lollipop Moderator Jun 24, 2019
    Nick 59, buntycubal and Shery4life like this.
  4. Shery4life Honeycomb Jun 24, 2019
    Thank you and 2 meter would be awesome and if you could pass to support, request for both round and flat cable please.
    Nick 59 likes this.
  5. Shery4life Honeycomb Jun 24, 2019
    I would like to order this but before I do can I ask if you or anyone has used this cable and if it does work with warp charge or dash charge.
    The link Is above mentioned. Please do message if anyone has used this cable thanks.
    Nick 59 likes this.
  6. keithnyc Lollipop Moderator Jun 24, 2019
    keithnyc, Jun 24, 2019 :
    Will mention it, but honestly, the costs (manufacturing, inventory etc.) involved in offering 4 different kinds of charging cables (flat and round for both standard and extended cables), or even 3 kinds if you're just talking about the extended cable, is likely going to be astronomical.
  7. Shery4life Honeycomb Jun 24, 2019
    I
    I'm hoping after oneplus bring the 2m cable they would only keep the 2m in inventory and then they will only have 2 version instead of 4.
    Nick 59 likes this.
  8. keithnyc Lollipop Moderator Jun 24, 2019
    I hear you. But then costs go up for all the devices. Because once they increase the length of the cable, they also need to redesign all
    the packaging (as an extra long cable will not fit in the current configuration). That involves re-configuring the design and manufacturing of the amazing packaging.....and re-designing and marketing this new package (and product testing that design as well). It's a very costly proposition...
  9. G_Neal_Craparo_Llll Gingerbread Jun 24, 2019
    Nick 59 and Shery4life like this.
  10. Shery4life Honeycomb Jun 24, 2019
    I do understand in the sense one plus could sell it as separate accessories which customer can buy. I know oneplus have 1.5 meter but 2 meter would be a perfect spot. Just wish they invest into 2 meter and I'm sure alot of people will buy it.
  11. Shery4life Honeycomb Jun 24, 2019
    Can you use the extension cable and post a pic of your phone charging speed. If you dial *#808# into dialer and choose the fast charge option that would be great. Because if I use any other cable to charge it says ac but does not exceed 1.5 amp. If you use the original warp charger/ dash charger and use this extension with original cable and post the result.
  12. G_Neal_Craparo_Llll Gingerbread Jun 24, 2019
  13. G_Neal_Craparo_Llll Gingerbread Jun 24, 2019
    keithnyc, Nick 59 and Shery4life like this.
  14. Shery4life Honeycomb Jun 25, 2019
    keithnyc and Nick 59 like this.
  15. Nick 59 Lollipop Jun 25, 2019
    keithnyc likes this.
  16. G_Neal_Craparo_Llll Gingerbread Jun 25, 2019
  17. keithnyc Lollipop Moderator Jun 25, 2019
    Nick 59 and Dresa91 like this.
