2
[3.5.x] A workaround solution to set vibrate while on Ring without using the alert slider.
  1. phoenixnghi
    Froyo Jan 8, 2017
    phoenixnghi , Jan 8, 2017 :
    As you knew, on 3.5.x we cannot lower the system volume to 0 or vib, this is annoying. It broke my Tasker automation tasks.
    I found out and tested this workaround for a week and it seems solves my problem. Hope it can help you, too.
    To set to vibrate even on Ring mode:
    - Go to Alert slider settings, enable Ring
    - Install AutomateIt
    - Create a task like this (Action: silent mode)
    - Done, you can set an automatic trigger for it when you go to work/school, or put a widget on your home screen to trigger it whenever you want.
    To escape from vibrate on Ring mode:
    - Just press vol up key
    OR
    - Using Tasker to automate it
    FAQ:
    [?] Why have to use 2 automation apps?
    - Because Tasker cannot do the first, AutomateIt cannot do the second one and vice versa (or maybe I don't know how to setup yet)
    xpevkirf and PLPeeters like this.
  2. PLPeeters
    KitKat Jan 8, 2017
    PLPeeters , Jan 8, 2017 :
    Nice workaround, thanks for posting! Shouldn't the action be "Set device sound mode to vibrate", though?
    Still hoping they will revert this...
    janguv likes this.
  3. legolittlebrick
    Ice Cream Sandwich Jan 10, 2017
  4. Rajneesh kumar sharma
    Eclair Jan 10, 2017
