3.5mm jack issue
  1. Ashwinmhatwalne
    Eclair Apr 23, 2019
    Ashwinmhatwalne , Apr 23, 2019 :
    Does anyone else have hardware problem with 3.5mm jack on op3t ,where the earphone pops out of jack on it's own?
  2. B_Wrath
    Nougat Apr 23, 2019
    B_Wrath , Apr 23, 2019 :
    Clear any dirt inside the jack.
  3. V!nayak
    Gingerbread Apr 23, 2019
  4. ghostofcain
    Marshmallow Apr 23, 2019
    ghostofcain , Apr 23, 2019 :
    If the wire comes off? You've got a different problem, the OPs issue sounds like accumulated debris in the socket causing the lack to pop out.
  5. V!nayak
    V!nayak , Apr 23, 2019 :
    i tried cleaning the hole, the wire stays but not that effectively. There no snug fit.
  6. ghostofcain
    Clean it again, it does sound like there is still debris in there, it's surprising how little dust is needed to prevent a proper fit.
  7. V!nayak
    I'm afraid that i might damage my phone with needle
  8. ghostofcain
    I certainly wouldn't stick anything metal in to clean the socket, try a wooden or plastic tooth pick, or canned compressed air.
  9. athaarv
    Jelly Bean Apr 23, 2019
    athaarv , Apr 23, 2019 :
    Strongly recommend compressed air
    vishvanjay and ghostofcain like this.
  10. G_Akhyar_ahmad_emcy
    Donut Apr 24, 2019
  11. ghostofcain
    Marshmallow Apr 24, 2019
    ghostofcain , Apr 24, 2019 :
    Same solution then, clean the bloody socket! It's very unlikely that over three years of use you have worn either the jack or the socket.
  12. G_Akhyar_ahmad_emcy
    Donut Apr 24, 2019
    G_Akhyar_ahmad_emcy , Apr 24, 2019 :
    thanks a lot buddy it got fixed there was so much dust in der.i cleaned it and now it's working.thankyou again
  13. rambokesar16
    Cupcake Apr 26, 2019
    rambokesar16 , Apr 26, 2019 :
    earphones jack automatically ejects out the earphones while listening to the music or any video .
    Krushank Prajapati likes this.
  14. ghostofcain
    Marshmallow Apr 26, 2019
    ghostofcain , Apr 26, 2019 :
    And that prevents you searching, how exactly?
  15. Dr.Krushank
  16. ghostofcain
    Again how does the jack issue prevent you searching the forum? There are many existing threads on this all with the same solution.
