3 button headphone help
  1. moonwyrm
    Ice Cream Sandwich Aug 15, 2014
    moonwyrm , Aug 15, 2014 :
    I have a pair of HTC in ear headphones from my Incredible S, which I adored, because the 3 button remote had skip and back buttons for listening to music, and not just volume controls. I plugged them into my OPO to listen to Spotify this afternoon, went ot skip tracks, and to my horror turned the volume down instead! I figured out a double tap on the pause button would skip tracks eventually, but I can't learn to live with that.
    Is there an app I can use to fix my previously android supported headphones back into skipping tracks? And if there isn't, can anyone recommend a new pair? I don't care about having a mic, I'd never use it, and I'm not interested in volume control on the remote, I just want to be easily able to skip tracks without taking the phone out of my pocket.
  2. drmartin
    Lollipop Moderator Aug 15, 2014
    drmartin , Aug 15, 2014 :
    http://forum.xda-developers.com/showthread.php?t=2671888
    Xiaomi Piston 2
    Supposedly these work, mine haven't arrived yet.
  3. moonwyrm
  4. drmartin
    No no they have more on the back! :) Visit the link ffs. ;-p
    OpofanIT likes this.
  5. moonwyrm
    Oh! I did go to the link, I'd actually seen the page before, but hadn't quite finished wading through the giant block of text yet.
    It does have three buttons, but the two on the back are for volume control, with the skipping and so on controlled by the middle button.
    This is exactly the same as the ones I have.
    drmartin likes this.
  6. ludo960
    Gingerbread Aug 15, 2014
  7. tanjim90
    tanjim90 , Aug 15, 2014 :
    does anyone know if the "apple earpods with remote and mic" work with the OPO ?
  8. ludo960
    ludo960 , Aug 15, 2014 :
    as far as i know apple earphones don't work with android at least the buttons
    tanjim90 likes this.
  9. moonwyrm
    Long press on volume changes the volume lots :p Double tap on the Play (centre) button does skip to the next track. But I specifically got HTC headphones instead of an audio brand, because I wanted the two extra buttons to skip tracks instead of control volume.
    I'm pretty sure this was part of HTC's Sense UI, as other HTC phones have this skip ability. surely there should be an app or plugin or something I could do to get it back?
  10. moonwyrm
    No, they use different resistance in wiring.
  11. rako
    Donut Aug 15, 2014
    moonwyrm and ludo960 like this.
  12. cametina
    Eclair Aug 15, 2014
  13. ludo960
    have you try that ?
    https://play.google.com/store/apps/details?id=se.jays.headsetcontrol
    moonwyrm likes this.
  14. argos285
    argos285 , Aug 15, 2014 :
    Some of the accessories will not be compatible with other devices, to me that is kind of dumb, but the companies want for their products to be used.
  15. rako
    Donut Aug 15, 2014
    cetinvselim likes this.
  16. drmartin
    Depends on the app, for Spotify it works just like on iPhone, in Google Music only the start and stop work.
    Edit: Sorry, volume does not work in any app. By Spotify working like iPhone I mean the double-tap or triple-tap part. :D
  17. moonwyrm
    Is it? Oh, that's good news. I've held off on the new update because I heard it had battery drain issues, but that they've been fixed in the next update.
  18. tanjim90
    but the mic works with everything right ?
  19. moonwyrm
    That looks like it might do the trick. I'll give the trial one a go, thank you!
  20. rako
    Donut Aug 15, 2014
    rako , Aug 15, 2014 :
    Cool, let me know how it goes.
