9
3 Day Review. Second Impressions Not That Good
  1. boukk
    Honeycomb Aug 10, 2014
    boukk , Aug 10, 2014 :
    It only mean your previous phone had worse battery, doesn't mean the opo one is good, cause it is not (I wouldnt class it as bad tho, just average).
    #41
  2. kazater
    Jelly Bean Aug 10, 2014
    kazater , Aug 10, 2014 :
    Well.. Mine doesn't. So I think you should get a replacement :)
    #42
  3. sien5
    Froyo Aug 10, 2014
    sien5 , Aug 10, 2014 :
    I came from a Galaxy S2 and this device is incredible, all depends on your expectation and where you came from :p
    #43
    Deactivated User likes this.
  4. Agavion
    Gingerbread Aug 10, 2014
    Agavion , Aug 10, 2014 :
    This is a fairly new phone and just like any new phone there will be bugs to fix. We should have faith that they will get these issues fixed. Have faith guys and gals ;)
    #44
    sien5 likes this.
  5. ysr2009
    ysr2009 , Aug 10, 2014 :
    I became a great fan of this phone.
    Only problem that bothers me a lot is the low call volume.
    I have my volume set at max, but sometimes it is hard to hear the other party.
    I really hope it is a software bug, which is fixable with OTA update.
    #45
  6. blackbeert
    Froyo Aug 10, 2014
    blackbeert , Aug 10, 2014 :
    Maybe there's something wrong, try and get a replacement.
    #46
  7. Radeon962
    KitKat Aug 10, 2014
    Radeon962 , Aug 10, 2014 :
    Mine is July 2 build date as well and mine has none of the issues you mention.
    I sold my Nexus 5 and Note 3 after using the OnePlus for a week.
    My experience has been the opposite of yours as the OnePlus has been the best phone I have used to date.
    #47
  8. frewys
    Froyo Aug 10, 2014
    frewys , Aug 10, 2014 :
    1. Hardware. I guess exchange is the only option depending on OPO dead pixel pollicy.
    2.I believe this is a "known" CM issue. Thought they fixed it though. Early reviews mentioned it I believe.
    3. As you mentioned. You haven't dropped calls. Bar status is relative. example
    full bar on a device may be between 70-100 reception. Where as the OPO has a higher quality of 90-100. However, this is speculation and experience from other models.
    4. Keep in mind. You usually play CRAZY with a new phone! Also (I had to look your phone up) your old phone has a smaller pixel count smaller screen not sure about the rating of the battery.
    Battery life is always hard to compare so many variables they may be doing work on your cell tower many connected at the same time bad weather may give worse reception etc.
    (http://www.phonearena.com/phones/Samsung-ATIV-S-Neo_id7934)
    Thanks though. It is always interesting to hear a personal review.
    #48
    rpark91 likes this.
  9. Ivanpoocky13
    KitKat Aug 10, 2014
    #49
  10. apu815
    Ice Cream Sandwich Aug 10, 2014
    apu815 , Aug 10, 2014 :
    some people complained about call volume and signal strength.
    If its a software problem, this should happen with every device.
    Now I think its a hardware issue. and some phones are defective. OP should be extremely careful about quality control issues and return policy
    #50
  11. boukk
    Yeah S2 is old, it s 3 generation back (soon 4), so yeah upgrade would be huge :) but then again you d have a huge upgrade going for a moto G 4G too which is only 150E ;)
    #51
    sien5 likes this.
  12. Khan31
    Froyo Aug 10, 2014
    Khan31 , Aug 10, 2014 :
    What about the speed on the phone is it up to par with the android elite ??
    #52
  13. boukk
    Depend what s your use, high end gaming, no, everything else , yes.
    #53
  14. jorgeshss
    Froyo Aug 10, 2014
    jorgeshss , Aug 10, 2014 :
    Install battery guru.it helps to increase the life of your battery up to 40%more in my experience
    #54
  15. PLPeeters
    KitKat Aug 10, 2014
    PLPeeters , Aug 10, 2014 :
    I'm not having any issues with that. I just found that the earpiece is very positional. You have to find the sweet spot to get normal volume :)
    #55
  16. davez
    davez , Aug 10, 2014 :
    Get the Oppo Find 7a :cool:
    With the student discount the price difference is not that big any more and you get a better OPO ;) without all the flaws
    #56
  17. Stew2
    #57
  18. SeriusNtentions
    Aug 10, 2014
    SeriusNtentions , Aug 10, 2014 :
    My work uses BlackBerry's. Before you cough, the OS 10.2 lets you easily side load android apps.
    I was considering buying a BlackBerry Z30 for myself since my work only provided me with a Q10, but of course if you compare the speed, and the front and the rear facing camera, well OPO squashes it! But if taking pics is not that important for you then the 8MP Camera might be good enough for you! You can buy them dirtily from Blackberry unlocked now here: http://store.shopblackberry.com/sto...op:Jul2014:wheretobuy:buy-smartphonesunlocked
    As you can see a Z30 is $499.00 with inferior specs but is a good workhorse
    #58
  19. SeriusNtentions
    Aug 10, 2014
    People in this forum have been boosting the sound using free programs such as Audacity. Try that!
    #59
  20. Gslide
    Gslide , Aug 10, 2014 :
    I reported the poor signal long time ago and the opo fan boys hated on me so bad. I knew it wasn't only me with this issue. But I'm still in love with my opo.
    Here are today's stats if you guys still don't believe.
    #60
    cnotes313 and rpark91 like this.
