2
Sound 320 kbps music is skipping beats
  1. kensabu
    Cupcake Jan 13, 2017
    kensabu , Jan 13, 2017 :
    I have been trying to play 320 kbps music tracks on the phone and it seems to akip beats and the song gets changed..i tried downloading all the versions including 128 kbps speed but the issue still remains..does anyone know what might be the issue? I even factory reset my phone but it didnt help at all
    siddharthsundaram and Mr_Krunal like this.
  2. Krishna2142
    Honeycomb Jan 13, 2017
  3. jayesh4195
    Froyo Jan 18, 2017
  4. adityarikame
    Froyo Jan 18, 2017
    adityarikame , Jan 18, 2017 :
    The same happens to me but only via Bluetooth audio or else it works perfectly fine .Did you try using a different audio player
  5. kensabu
    Cupcake Jan 18, 2017
    kensabu , Jan 18, 2017 :
    yes itried using google play..gives me the same issue
  6. Dhanrajmawani
  7. MrCharlie
    Gingerbread Jan 18, 2017
    MrCharlie , Jan 18, 2017 :
    Seems that it is possible to disable all Audio modifications in settings from the audio settings WITH connected headphones. (source: comments under PocketNow OP3T audio review on YT)
  8. G_Aapoorv_Malpekar_SsCF
    Froyo Jan 18, 2017
  9. Krishna2142
    Honeycomb Jan 18, 2017
    Krishna2142 , Jan 18, 2017 :
    can u provide the link ?
  10. MrCharlie
    Here it is (was not sure if YT links are allowed here):
    Was referring to 'Iisakki Kaaretkoski' comment (1 week ago)
  11. Rkg1
    Cupcake Jan 20, 2017
  12. siddharthsundaram
    Cupcake Feb 19, 2017
    siddharthsundaram , Feb 19, 2017 :
    I too am experiencing the same issue I tried different players however in some cases there's no skipping but there was small shrilly sounds here and there. I used default player and power amp player.
    I hope there is fix for it as it's difficult to listen to audio in op 3 t (T_T)
  13. Rahul Chaudhary2207
  14. shawn_nie
    Cupcake Aug 3, 2018
    shawn_nie , Aug 3, 2018 :
    Hey, same problem on my 5t.
    Is it the priority of audio process or buffer size?
