10
33R: Typing/touch sensitivity issues worse?
  1. nurtext
    Eclair Sep 6, 2014
    nurtext , Sep 6, 2014 :
    Did someone tried to go back to 25R and see if that fixes the issue?
    #81
  2. spencer1620
    Ice Cream Sandwich Sep 8, 2014
    spencer1620 , Sep 8, 2014 :
    I'm in the same boat op needs to get it sorted quickly or the phones going back I don't care how cheap it is if part of the screen is yellow and you can't type with it it's no use to any one
    #82
    Wah007 likes this.
  3. mosesv26
    Jelly Bean Sep 8, 2014
    mosesv26 , Sep 8, 2014 :
    Same here if I press it slower it goes thru no problem.
    #83
    Skf123 likes this.
  4. nurtext
    Eclair Sep 9, 2014
    nurtext , Sep 9, 2014 :
    Back on 25R now and problems are gone. I switched multiple times between 33R and 25R forth and back and I noticed, that the problem conjures with the animation of certain UI elements.
    E.g. if you swipe in the app drawer, a first tap right after the swiping-animation won't be detected. But if you wait half a second it get's detected without any problem so far. Same happens to folder open/close and even when using keyboard (which also has animations like key press or key popup).
    So it's not a real hardware issue as far as I can tell you, but a thing of timing and/or sensitivy in combination with unfinished animations.
    I'll cross my fingers for the next update and stay on 25R as long as the problem persists.
    #84
  5. akshayk18
    Cupcake Sep 17, 2014
    akshayk18 , Sep 17, 2014 :
    any solutions for the touch sensitivity? pretty annoying when doing double tap on browser or typing messages.. very bad response in touch
    #85
  6. hegde.23.anu
    Gingerbread Sep 17, 2014
    #86
  7. BakaShin
    Froyo Sep 20, 2014
    #87
  8. jkbhso3
    Jelly Bean Sep 20, 2014
    #88
  9. southaven1981
    Ice Cream Sandwich Sep 20, 2014
    southaven1981 , Sep 20, 2014 :
    Cyanogen always incorporates new things in each update, which may or may not fix or destroy other things. However They are one of the most used roms in the world.
    #89
  10. TheTubTruck
    TheTubTruck , Sep 20, 2014 :
    That won't help, it's an issue with the screen software, not the keyboard.
    It's in the latest nightlies, so we can expect it to be fixed in the next OTA
    #90
    BakaShin likes this.
  11. jkbhso3
    jkbhso3 , Sep 20, 2014 :
    It's not meant to be a fix. More like a work around. I can mash as fast as I want on my phone and type nothing but gibberish and the predictive text works so well that it comes out coherently.
    #91
    TheTubTruck likes this.
  12. jpal
    Cupcake Sep 20, 2014
    #92
  13. TheTubTruck
    Ah, People say Swiftkey has good word prediction, never liked that keyboard though
    #93
  14. jkbhso3
    I like that I can link my Facebook, Gmail, Hangouts to the app and it will read through all the txt to get an idea of my speech patterns and also add words to my personal dictionary. That's why it works so well for me.
    #94
  15. TheTubTruck
    #95
    Raffi5555, BakaShin and jkbhso3 like this.
  16. Pablo1986
    Pablo1986 , Sep 20, 2014 :
    I'd been waiting for it almost a week... dont know why there is a fix but takes soo much time to release it...
    #96
  17. xf4d3
    xf4d3 , Sep 20, 2014 :
    They want to test it properly, so it wont be like the 30O update again.
    #97
    Pablo1986 likes this.
  18. Sushant
    Gingerbread Sep 20, 2014
    Sushant , Sep 20, 2014 :
    Mid october
    #98
    BakaShin and Jayception like this.
  19. kovalski
  20. Wah007
    Jelly Bean Sep 21, 2014
    Wah007 , Sep 21, 2014 :
    That's long. They should give this priority.
    If people don't put up with this unacceptable issue OP will go bankrupt.
