3rd party charging brick and Warp Charge via OnePlus 7 Pro
  1. O1574089453930 , via OnePlus 7 Pro , Sep 27, 2020 :
    Can OnePlus 7 Pro warp charge with any 3rd party charging bricks that can supply 30 watts power (supposed I use official usb cord)? Or I need to use only official brick to get Warp Charging?
  2. Tokolozi
    Most Original Avatar Sep 30, 2020
    Best Answer
    Tokolozi , Sep 30, 2020 :
    Correct, since warp charge is propietary tech, and actually a lot of the process is done within the charging brick.
    O1574089453930 likes this.
  3. Batman360
    OnePlus Accessory Tester Sep 29, 2020
  4. Tokolozi
    Most Original Avatar Sep 29, 2020
    Tokolozi , Sep 29, 2020 :
    Warp charge 30 is only possible with the original adapter. Since oneplus isn't using the USB PD protocol most other 30W chargers are using
  5. O1574089453930 , via OnePlus 7 Pro , Sep 30, 2020 :
    Would I get Warp Charge or just charge?
  6. O1574089453930 , via OnePlus 7 Pro , Sep 30, 2020 :
    So the watt does not matter, only original bricks can Warp Charge the phone?
    Auristic likes this.
  7. Auristic
    Lollipop Sep 30, 2020
    Auristic , Sep 30, 2020 :
    Just charge.
    O1574089453930 and Tokolozi like this.
  8. O1574089453930 , via OnePlus 7 Pro , Sep 30, 2020 :
    What about dash charging? I have been hearing people saying about it but have never seen it myself, not sure if this technology is applicable to OP7Pro. Does it also require official bricks or 3rd party with sufficient watt will do?
    Thank a bunch!
  9. Tokolozi
    Dash is the older name for warp. But they work together, I would still recommend buying an official adapter from the oneplus store in any case.
