2
3T battery consumption concerns
  1. Timothy Lol
    Donut Jun 25, 2017
  2. Atzenman
    Froyo Jun 25, 2017
  3. ginnamann
    Froyo Jun 25, 2017
    ginnamann , Jun 25, 2017 :
    clear cache and dalvik from the recovery and update to 4.1.6 there is a huge boost
  4. ginnamann
    Froyo Jun 25, 2017
  5. Daasty
    Honeycomb Jun 25, 2017
    Daasty , Jun 25, 2017 :
    Nevera use Clean master, It's garbage! It says it cleans but it doesn't. It just waste battery in the background! If you want a cleaner, install CCleaner, but it doesn't clean cache due to Android from 5.0 doesn't let thrid-party apps clean it. That's why Clean Master does nothing!
  6. G_Saurabh_Trivedi_gNPx
    Cupcake Jun 25, 2017
  7. Timothy Lol
    Donut Jun 25, 2017
    Timothy Lol , Jun 25, 2017 :
    Alright thanks for the tip :) just installed ccleaner.
    Daasty likes this.
  8. Daasty
    You are welcome! ;)
    Timothy Lol likes this.
  9. Timothy Lol
    Donut Jun 25, 2017
  10. G_Jon_Blanco_VgdL
  11. Timothy Lol
    Donut Jun 25, 2017
    My battery died and here is the "score". I do see some 3T owners having over 6 hours of SOT using beta version 9 of OOS though...
  12. Timothy Lol
    Donut Jun 25, 2017
    CCleaner doesn't seem to be able to clear my app cache though :(
    Daasty likes this.
  13. Daasty
    Yes, that's what Clean Masters says it cleans, but system does not let it do that. It creates a lot of garbage and the deletes it, so that you can see you have more space. Cheetah Mobile is just heavily lying users with that app. CCleaner is honest with that. What CCleaner does is tell you what apps has more cache, just click on them to clean it manually. By the way it can clean empty folders, Download folder, WhatsApp data...
  14. ginnamann
    Froyo Jun 25, 2017
    then you have to clean cache to recalibrate the battery i have faces same problem in other smartphones and this proves a good solution
  15. akkizininstaz
    Gingerbread Jun 25, 2017
    akkizininstaz , Jun 25, 2017 :
    im gettin pretty good battery life on beta 9 .. around 6 hours of sot with jio 4g on all the time.. 3+ hours of calling ...good amount of instagran n and lil bit of gaming
  16. G_Oscar8848_BvCl
  17. Timothy Lol
    Donut Jun 26, 2017
  18. thisizprk
    Donut Jun 26, 2017
    #38
  19. G_Steve_Southall_rUIr
    Donut Jun 26, 2017
    G_Steve_Southall_rUIr , Jun 26, 2017 :
    My battery life is odd, I'll lose 20% in just over an hour without even using my phone, I had problems with android system using a lot of power till I cleaned the cache this is my battery after a days use without charging in between with light usage as been at work
    #39
  20. G_Steve_Southall_rUIr
    Donut Jun 26, 2017
