OxygenOS 3T issues after upgrading to 5.0.7
  1. OLS_TheWho Gingerbread Dec 6, 2018
    OLS_TheWho, Dec 6, 2018 :
    Dear OnePlus and Community.
    It looks like my OnePlus 3T does not "like" the latest OTA Update to 5.0.7 .
    I am facing two problems since the Update got installed:
    1. Mobile Broadband connectivity is weaker than before
    Since updating phone calls are getting interrupted more often than before.
    The network connectivity seems to be weaker than before.
    There is one "blind spot" on the German Autobahn and this caused bad phone quality
    in all previous Firmwares.
    After upgrading to 5.0.7, the phone calls are getting disconnected five to six times.
    2. Camera needs much longer to focus
    All previous Firmwares showed a good camera speed.
    After upgrading, the camera needs several seconds to focus which makes "snapshots" impossible.
    3. Bluetooth connectivity gets interrupted within a call
    My Bluetooth Headset gets disconnected without any change within a phone call.
    This is a little annoying as having a phone call with your boss should not get interrupted
    from your side.
    Might be someone has good ideas to solve the issues.
    Reset and reinstall is not a great solution.
    Some phone Details:
    Modell: ONEPLUS A3003
    OxygenOS-Version: 5.0.7
    RAM: 6GB
    Storage: 128GB (31.40 of 122GB used = 26%)
    Android-Version:8.0.0
    Security Patchlevel: November 1st 2018
    Build Number: ONEPLUS A3003_28_181118
    Thank you and "Schönen Nikolaus".
  2. Akhshay Srinivasan Marshmallow Dec 6, 2018
    Akhshay Srinivasan, Dec 6, 2018 :
    Hi 3T user,
    We're sorry to hear a list of bugs from your end.
    Thanks for the infos. provided.
    Request you to submit your bugs here.
    Thank you.
    sommersy, NeVeR_SeTTLe and OLS_TheWho like this.
  3. OLS_TheWho Gingerbread Dec 6, 2018
    Dear Akhshay.
    Thank you for your reply.
    I have created three reports.
    Kind regards
    Robert
    Akhshay Srinivasan likes this.
  4. Akhshay Srinivasan Marshmallow Dec 6, 2018
    Hi Robert,
    Glad to hear that. You'll be directed by the Op team based on your choice of report.
    Thank you !
  5. OLS_TheWho Gingerbread Dec 6, 2018
    Thank you Akhshay.
    It is great to see not that advanced "OnePlus Community Users" are getting a helping hand from your side.
    Hope you and your family will spend a great Christmas time.
    Robert
  6. Akhshay Srinivasan Marshmallow Dec 6, 2018
    Hey there,
    Our pleasure Robert :) Feel free to post your issues here.
    Thanks a ton man :) Happy Xmas 2k18 ;)
    P.S. : The next time, request you to search for a question related to yours first and then create a thread.
    OLS_TheWho likes this.
  7. Bouncer71 KitKat Dec 6, 2018
  8. OLS_TheWho Gingerbread Dec 6, 2018
    hi.
    I am using the stock camera...
    1.5.0
  9. Bouncer71 KitKat Dec 6, 2018
  10. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Dec 6, 2018
    NeVeR_SeTTLe, Dec 6, 2018 :
    Hey there, try going into Settings --> Apps --> Camera --> Storage --> Clear cache and clear data. Reboot. See if this works for you :)
  11. OLS_TheWho Gingerbread Dec 6, 2018
    Thanks mate.
    I performed the steps you mentioned but have to check the Camera.
    It came up with the "initial tips" thingie.
  12. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Dec 6, 2018
    Please report back
  13. OLS_TheWho Gingerbread Dec 6, 2018
    For the first tests it looks good -> camera seems to focus faster.
    I have to test this weekend in "live action"
  14. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Dec 6, 2018
    Glad to help :) If you have any problems going forward, just continue here or DM me. :)
  15. OLS_TheWho Gingerbread Dec 6, 2018
  16. Paschfire Jelly Bean Dec 9, 2018
    Paschfire, Dec 9, 2018 :
    You can also try OP camera versions 2.5.33 ~ 2.5.34(visit APKmirror site to download).
    For some reason OP only included camera version 1.5.X in all latest OOS 5.0.X builds, though version 2.5.33 was the latest camera build include with previous Open Beta 30/39 releases.
    You may want to give them a try, I'm using version .34 without issues on my 3T running OOS_5.0.7.
  17. OLS_TheWho Gingerbread Dec 9, 2018
    OLS_TheWho, Dec 9, 2018 :
    Thank you.
    I don't get the point why OnePlus does not update the camera version of there is an updated release available.
    From my point of view, keeping the phone as "stock" as possible could bring the best experience.
    Well, resetting the camera made it working more less good again.
    I was using "eBay Kleinanzeigen" (eBay Fleemarket or so) and the cam hung several times. This might be related to the eBay app itself.
    Thank all of you for your support which is highly welcome!
  18. OLS_TheWho Gingerbread Dec 9, 2018
  19. Paschfire Jelly Bean Dec 9, 2018
    That's version isn't built for the 3/3T, some features may not function properly.
    Form what I've read double -tap power button to launch camera doesn't work correctly. photo quality might also suffer being that it's developed for newer OP devices.
  20. OLS_TheWho Gingerbread Dec 9, 2018
    I am just facing the double tap thingie.
    Reinstalling the official / original version brought it back.
    Updating to the latest Camera App brought new "things" which are not available in the original version.
    I am able to use the power button to open the camera again.
