19
4.1.4 OTA Hot fix for screen flickering issue
Thread Status:
Not open for further replies.
  1. a.k.h.i.l
    Gingerbread May 20, 2017
  2. Dhritiman5
    Donut May 20, 2017
    Dhritiman5 , May 20, 2017 :
    Apparently its not
  3. Dhritiman5
    Donut May 20, 2017
  4. lunchboxLarry
  5. gaurav.malhotra
    Honeycomb May 20, 2017
  6. Pranav k Patel
    Pranav k Patel , May 20, 2017 :
    i also didnot get the update i m 1+3user
  7. madnwise
    Eclair May 20, 2017
    madnwise , May 20, 2017 :
    The change log is showing "Fixed screen flickering for Indian region"
  8. Rey1+
  9. bharathpsd
    bharathpsd , May 20, 2017 :
    just install the VPN get the update. it's simple. if you are in India or anywhere else.
  10. lunchboxLarry
    Hansota likes this.
  11. varma246
    Lollipop May 20, 2017
  12. bharathpsd
    it is only for the OP3 variants in India. other regions doesn't have to worry about it. it's just a bug fix for Indian variants which other regions doesn't .
  13. bharathpsd
    you will get it. wait until it arrives. the update is for OP3 only and that too for Indian users.
  14. Hansota
    Froyo May 20, 2017
    Hansota , May 20, 2017 :
    But it's only an update for India. Or? The description says it fixes a problem which occurs in India
  15. Neel_7158
    Donut May 20, 2017
  16. Pranav k Patel
    its bug fixing its of no use
  17. camohan
    Marshmallow Moderator May 20, 2017
    camohan , May 20, 2017 :
    Thread merged. If you are not from India, you should probably not update.
  18. Nanjunda K T
  19. Nanjunda K T
    Nanjunda K T , May 20, 2017 :
    go and check once
  20. Nanjunda K T
    look buddy let make you clear , new os updates brings bugs , its just a bug fix nothing to do with other activity
