15
OxygenOS 4.1.7 causes battery drain
  1. Rachel.EricAnderson
    Cupcake Aug 29, 2017
    Rachel.EricAnderson , Aug 29, 2017 :
    I never had issues with OnePlus until the 4.1.7 update. 4.1.7 causes battery drain on all three of my families devices.
    We hope a update fix will come out soon!!
  2. G_Daniel_Amsalem_pGvK
    Froyo Aug 29, 2017
  3. G_Violaknight1989_Viola_
    Gingerbread Aug 29, 2017
    G_Violaknight1989_Viola_ , Aug 29, 2017 :
    agree .
    till now everything was ok . this last update is horrible when comes about battery optimization.
    its draining battery optimization in the oposite way .
  4. adheippal
    Donut Aug 29, 2017
    adheippal , Aug 29, 2017 :
    Exactly. Please resolve the problem soon. The frequent need to charge the phone us just killing the purpose of it.
  5. Jatin Dhir
    Eclair Aug 29, 2017
    Jatin Dhir , Aug 29, 2017 :
    battery is drained too much.. its horrible thing.. the update is worst!! plz fix it soon
  6. andrea.niccolini
  7. ardent_abhishek
    Donut Aug 29, 2017
  8. hananph
    Eclair Aug 29, 2017
  9. Chiragmanak
  10. Siddhanth Vs
  11. shaikhashraf739
    Eclair Aug 29, 2017
  12. KabirKunwar
    Froyo Aug 30, 2017
    KabirKunwar , Aug 30, 2017 :
    i was getting 4.5hrs SOT with the whole of SOT being used with wifi streaming videos on youtube + facebook + messenger + browsing.
    after the update dropped to 4hrs or less.
    so i factory reset the phone.
    will review if this improves the battery.
    previous attempts by just clearing cache had not improved any.
    one loss from factory reset was google now cards/feed.
    i had enabled it by clearing the data from the google app / play services / framework, running vpn and all; now no matter what i do, it says my account does not support feed.
    i will miss asking assistant to make my reminders. <sigh>
    will update on battery improvement if any.
  13. kumar alok2091
    Honeycomb Aug 30, 2017
    kumar alok2091 , Aug 30, 2017 :
    I am changing my review too...first day I was excited didn't noticed sot....after 3 to 4 days of usage....it is like no change in battery life....what the heck
  14. itonik
    Cupcake Aug 30, 2017
    itonik , Aug 30, 2017 :
    Agree. More than 1GHz in idle. But nothing suspicious in battery menu
  15. maverick2
    Donut Aug 30, 2017
    maverick2 , Aug 30, 2017 :
    A mi tambien me pasa lo mismo, desde que actualicé a la 4.1.7 el one plus 3 se calienta y me drena la batería.
    Esperemos que one plus lanza una actualización que arregle este problema.
  16. G_David_Stevenson_qPkC
  17. KabirKunwar
    Froyo Aug 30, 2017
    MAJOR IMPROVEMENT after Factory Reset for Oneplus 3
    with 4.1.6 I was getting around 4.5hrs
    after update to 4.1.7 it degraded to 3.5 to 4hrs
    after update 100% to 5% gave me around 5hrs 20min
    usage scenario:
    - screen calibration -sRGB
    - Dark theme
    - Brightness on auto; cranked up while watching videos and as required; usually below 50%.
    - aggressive doze and app hibernation on; but only for those which actually do not need to use background data or need to be active whatsoever. Off for all general apps like fb, messenger, insta, youtube, playstore etc etc
    - wifi always turned on (cellular data off)
    - whenever used, uses for media consumption and social media scrolling, videos mostly.
    thank god the factory reset did it for me.
    I use fb too much; its a battery hog. So probably can get more than 5.5hrs with moderate use.
    remedy likes this.
  18. SathiShree
  19. Ninabeertje
    Ninabeertje , Aug 30, 2017 :
    Really terrible.. Phone is getting hot even wihout using it and you can see battery draining.. Thiz was not the case with 4.1.6.. Also 4G was gone.. Fixed that for it seems to work
  20. remedy
    KitKat Aug 31, 2017
    remedy , Aug 31, 2017 :
    Please everybody, clear cache from Recovery.
    Follow these steps:
    Turn phone off
    Turn phone on with volume down pressed, stop pressing power but keep volume pressed.
    Once in menu, third option is English. With volume button you can go down. Enter with power button.
    You see menu options, press wipe cache and data
    New menu
    Wipe cache only
    Reboot.
    MitoMonkey likes this.
