80
ROM [4.4.4] [BACON] Mahdi-Rom 2.7
  1. simoscorpion
    Ice Cream Sandwich Aug 18, 2014
  2. famonaco
    Gingerbread Aug 18, 2014
    famonaco , Aug 18, 2014 :
    mate i can install it over the previous version?
    or not?
    Upgrading from an earlier version: (not recommended)
    - Copy the ROM ZIP to your SDCard
    - Boot into Recovery
    - Flash the ROM zip from SDCard
    - Reboot
  3. Zoosh
    Honeycomb Aug 19, 2014
    Zoosh , Aug 19, 2014 :
    install over the top of a previous build of Mahdi works fine thats all i do each time
    famonaco likes this.
  4. @CallipH
    Eclair Aug 19, 2014
    @CallipH , Aug 19, 2014 :
    Does the update have the newest kernel baked in? I checked my about phone, and it appears it did, but I didn't see that in the logs... Of course, I was already using it...
  5. Rhenie
    Gingerbread Aug 19, 2014
    Rhenie , Aug 19, 2014 :
    I managed update to mahdi-2.7-bacon-20140818 but before doing this I have to reflash the TWRP.I don't know why but when in the recovery the screen goes black only the hardware buttons lights up.This only happened after last updated.Once I get back in TWRP I flashed the new update and gapps 20140811.See how the new update goes for the next few days.Not a big issue on this ROM so far.
  6. alex inthi
    Ice Cream Sandwich Aug 19, 2014
    alex inthi , Aug 19, 2014 :
    TWRP. I just flashed rom and a kernel. Now it works fine. Thank you
  7. bcsheng
    Eclair Aug 19, 2014
  8. famonaco
  9. alex inthi
  10. jerryr88
    jerryr88 , Aug 19, 2014 :
    Been hearing great things about mahdi rom and im tempted to try it since 30O killed my battery life :(
    Ive always rooted and flashed diff roms on my phones but havent taken the plunge with my opo because we need to unlock the bootloader and I didn't wanna wipe lol
    But now that i saw a mahdi rom review on xda im very intrigued
    Can anyone tell me how long the battery lasts with mahdi rom?
    Before the 30O update i was getting 18-19hr battery and 6-7 hrs screen on time and now im getting less than half plus i also want the cool hover and peek notifications :D
    Thanks :cool:
    johnwillyums likes this.
  11. johnwillyums
    johnwillyums , Aug 19, 2014 :
    Yes, jerryr88, me too. I saw Jared Busch's video on XDA.
    I've only done this a couple of times before, so a relative newbie.
    I intend to follow Chromium's unlocking/rooting tutorial (in this section of the forum) is that ok?
    Then follow the Mahdi installation on this thread.
    Also, I'm on ART at the moment, would I need to revert to DALVIK runtime before starting, or would that happen anyway?
    Any help/suggestions would be welcome, thanks all, John Williams :)
    jerryr88 likes this.
  12. skydayzer
    skydayzer , Aug 19, 2014 :
    I can go a day with 8-9hrs SOT
    jerryr88, johnwillyums and MAHDI-ROM like this.
  13. skydayzer
    Yea Chromium's unlocking/rooting tutorial is ok...
    Dalvik Will be installed automatically...
  14. johnwillyums
    Thanks for you reply skydazer. I had root access before, but the 300 update knocked it off.
    So there's that, plus the fact that I always intended to try out different ROMs, and this one looks like an obvious choice :), plus the battery drain.
  15. skydayzer
    Flash this: http://download.chainfire.eu/452/SuperSU/UPDATE-SuperSU-v2.02.zip
    You'll get your root back
    PS: Use the reply... so i can see it fast to reply.. You're Welcom
    johnwillyums, jerryr88 and MAHDI-ROM like this.
  16. johnwillyums
    Hello skydayzer, thanks for the further help. I'm at work at the moment, so I can't do this right now.
    When I rooted before I used CWM, and have ROM Manager in my app drawer. Of course that now asks for root, I did have TWRP, as well, but that doesn't seem to be there now.
    SDK tools, and ADB, should still be on my pc.
    Are you saying that, I download from your link to my pc, or my phone?
    Thanks for the great input. John :)
  17. 1eunique1
    1eunique1 , Aug 19, 2014 :
    Im going to have to give this a try. Specially since i finally got TWRP recovery to work
    MAHDI-ROM likes this.
  18. mklpickle
    Cupcake Aug 19, 2014
    mklpickle , Aug 19, 2014 :
    Is anyone using the r12 version of franco kernel? I'm still on stock kernel. Didn't experience reboot issue when moving to Mahdi Rom. Not sure if I need to update kernel. If so, which kernel, and why (as opposed to personal preference).
    Thanks in advanced for advice!
  19. famonaco
  20. skydayzer
    Yes.. flash it in recovery and you're good to go
    johnwillyums and jerryr88 like this.
