80
ROM [4.4.4] [BACON] Mahdi-Rom 2.7
  1. jerryr88
    Honeycomb Aug 19, 2014
    jerryr88 , Aug 19, 2014 :
    Thanks for the reply
    Gonna take the plunge and unlock bootloader today and flash mahdi rom
    Anything else i should know before doing this? Ive heard about diff kernels do we have to do any of that? Or are u running mahdi rom he way it comes ?
    Thanks for your help!
  2. skydayzer
    Gingerbread Aug 19, 2014
    skydayzer , Aug 19, 2014 :
    Am now running Mahdi with Furnance kernel..
    But I recomend you go with Stock kernel that comes with it
    johnwillyums, MAHDI-ROM and jerryr88 like this.
  3. Zoosh
    Zoosh , Aug 19, 2014 :
    I have tried 3 diff kernels and to be honest i didnt notice much difference so if i where you try the standard kernel in Mahdi play around with it for a bit then try franco so you can see the difference for yourself. It takes 5 seconds to flash so its easy to flash it back to a standard kernel.
    Personally my daily is the standard kernel no reboots solid as a rock atm
  4. jerryr88
    Thanks guys!!!
  5. Rhenie
    Gingerbread Aug 20, 2014
    Rhenie , Aug 20, 2014 :
    As always I stayed on stock kernel when I see not much different.
  6. jhodder
    Ice Cream Sandwich Aug 20, 2014
    jhodder , Aug 20, 2014 :
    Wow. Insane battery life. 11:36 of battery time, 4:42 screen on time, and I am still at 51% charge.
    Running latest Mahdi build and Franco R13. Greenify to shut down unused apps. Nothing else is customized. No under clocking. Nothing.
    Insane.
    Edit: WiFi was on for all 11:36 and I had :51 of phone talk time.
    hassan_1000 and skydayzer like this.
  7. teqnix
    Lollipop Aug 20, 2014
    teqnix , Aug 20, 2014 :
    Wow that's insane!
  8. kwcpaul
    Froyo Aug 20, 2014
    kwcpaul , Aug 20, 2014 :
    Agree that with Wifi on, the battery life is insane with the same Mahdi + Franco combination! I sleep with my phone at 93%. When I wake up the next morning, the phone is still at 93%.
    The phone has slept well!
  9. circl3
    Cupcake Aug 20, 2014
    circl3 , Aug 20, 2014 :
    Sorry about my bad english.
    But yesterday i unlocked my bootloader, installed TWRP Recovery, root,.... and i installed Mahdi Rom 2.7. Everything was ok, i used it normal and didn't have errors. So i charged my phone. I woke up this morning and saw my oneplus one turn off, couldn't turned on and boot Recovery or Fastboot. Even i plugin my phone, no charge icon show ??
    Please help me. I just bought it yesterday
  10. @CallipH
    Eclair Aug 20, 2014
    @CallipH , Aug 20, 2014 :
    Not what you want to hear, but I've seen a few of these posts, almost verbatim in various threads (is, not a rom issue)... I'd contact OnePlus if you cannot get into recovery, fastboot, etc.
  11. alex inthi
  12. alex inthi
    alex inthi , Aug 20, 2014 :
    And one more thing.
    Is you kernel with kexec-hardboot patch? If not can you merge it and make a kernel?
  13. jerryr88
    Honeycomb Aug 20, 2014
    jerryr88 , Aug 20, 2014 :
    any way to back up my phone before i unlock my bootloader and wipe everything? in case something goes wrong
    i was rooted but unfortunately it went away when i updated to 30O
    so im on stock cm simple recovery
    i'll be using Mechanical mac toolkit for mac os to unlock bootloader, root and flash mahdi
  14. polinauer
    polinauer , Aug 20, 2014 :
    Wow!
    I had the drain issue so I decided to shift to mahdi ROM and installed it from the scratch. So far so good, the ROM works smoothly but over night the battery dropped 10% in airplane mode.
    I have currently the one of 08/18.
    Does it have TVE battery fix?
    Should i go for Franco kernel as you did?
    Thanks
  15. jerryr88
    just flashed mahdi rom, took me a while to figure out if my bootloader was unlocked but after that i flashed twrp and rooted then proceeded to flash mahdi
    gotta say im excited im hoping for the best! and that my battery life will be much better
    Thanks to everyone for their help :D
    johnwillyums likes this.
  16. exitjen
  17. kwcpaul
    Froyo Aug 20, 2014
    You may run the stock kernel a few days first and compare it with franco. Then u decide which one to use. Wt is tve battery fix??
    Zoosh likes this.
  18. Zoosh
    Zoosh , Aug 20, 2014 :
    can anybody confirm if the headphone socket works ok when using mahdi newest build with franco 13?
  19. Zoosh
    you might want to leave the standard cm11 build on your phone and a franco rom somewhere before flashing for the first time just in case you want to roll back just boot into recovery i prefer twrp then you can just reflash whichever image
    jerryr88 likes this.
  20. Zoosh
    yep i can now confirm it works ;-)
