80
ROM [4.4.4] [BACON] Mahdi-Rom 2.7
  1. azori
    Froyo Sep 26, 2014
    azori , Sep 26, 2014 :
    You probably flashed wrong kernel-version. You should flash AOSP-based franco r20, not CM11s based. Just flash the right one and you are fine!
    skyfail and Rmaier14 like this.
  2. Kevin Liu
    Honeycomb Sep 27, 2014
  3. azori
    Froyo Sep 27, 2014
    azori , Sep 27, 2014 :
    Just check out the previous page, there you can find that newest Mahdi is v2.8, release date 24.9.
  4. Kevin Liu
    Kevin Liu , Sep 27, 2014 :
    thanks, I overlooked:p
  5. eshoxx
    Froyo Sep 28, 2014
    eshoxx , Sep 28, 2014 :
    Mahdi didn´t work 4 me. Wasn´t able to do phone-calls. Had to switch to CM11, then everything was fine...
  6. isaiah_marin
    Ice Cream Sandwich Sep 30, 2014
    isaiah_marin , Sep 30, 2014 :
    So I flashed Franco r20 got visual artefact . Reflashed mahdi ROM cause I couldn't stand i . Saw the update in r22 that fixed this. Flashed it But get I'm still getting yes I downloaded the right verso . Anyone else getting this with franco
  7. isaiah_marin
    I did this and I'm still getting visual artefacts on my screen
  8. AnssiH
    Gingerbread Sep 30, 2014
    AnssiH , Sep 30, 2014 :
    What mahdi version you're on? Flash the 23/09 build and you will be fine
  9. mu1zz786
    Honeycomb Sep 30, 2014
    mu1zz786 , Sep 30, 2014 :
    looks good but i think i should stick with onplus rom dont want to go through the long process of changing the rom
  10. azori
    Froyo Sep 30, 2014
    azori , Sep 30, 2014 :
    Update your current ROM. Or disable hw overlays in developer settings.
  11. azori
    Froyo Sep 30, 2014
    I thought it was 24/9, could be wrong though.
  12. AnssiH
    You're right :) made a typo :D
  13. androfreak
    Froyo Oct 1, 2014
    androfreak , Oct 1, 2014 :
    is this normal? when i insert my sim card it automaticaly starts to force clode with error: systemui has stopped.
    edit: switched to paranoid and it works fine. seems like this rom is NOT stable atm
  14. AnssiH
    Gingerbread Oct 1, 2014
    AnssiH , Oct 1, 2014 :
    Stable for me. Did you clean flash?
  15. oxxshadow
    Gingerbread Oct 2, 2014
  16. Andril
    Honeycomb Oct 2, 2014
  17. yonoshiro
    Ice Cream Sandwich Oct 2, 2014
    yonoshiro , Oct 2, 2014 :
    Hey @MAHDI-ROM , @Moose0704 . Thank you guys very much for creating this amazing ROM. It truly gets better with each iteration. However, I have observed that the display calibration options have been removed. It is my understanding, thanks to guidance from zephik on xda, that this is due to CyanogenMod removing this functionality.
    I am just curious. Do you guys have any idea why they did that? It is the one thing I miss as my screen looks so washed out without my tweaks. Lol.
  18. 999blb
    Froyo Oct 2, 2014
    999blb , Oct 2, 2014 :
    I was wondering the same thing here.
    yonoshiro likes this.
  19. deadwarrior
    deadwarrior , Oct 2, 2014 :
    guys, how do i enable Immersive Mode? The option is greyed out under Settings > Buttons > Power Menu. I'm running Mahdi 2.7 build 20140903.
    EDITED: Nvm, found it under Settings > UI settings
  20. Kevin Liu
