48MP RAW in Pro mode.
  1. ReapR7
    Froyo Oct 14, 2019
    ReapR7 , Oct 14, 2019 :
    So the Pro mode allows 48mp jpeg but not the same case for RAW file.
    The raw files are of only 2984x3984 only!
    Which is even lower than the raw file dimensions of OnePlus 5T camera!
    Please fix this issue?
  2. Horsault
    Marshmallow Moderator Oct 14, 2019
    Horsault , Oct 14, 2019 :
    48Mpx is on main camera only, in 4:3 full captor mode.
    If you're shooting from another camera (zoom or wide angle, or even numeric intermediate zoom) you'll only get this camera full resolution.
    If you're using another ratio, image is cropped accordingly.
    Liehjan likes this.
  3. ReapR7
    Froyo Oct 14, 2019
    The main 48mp camera isn't producing the 48mp RAW file just like it produces the 48mp jpeg file in 4:3.
    As I'm taking about the Pro mode so it already means that I'm talking about the main 48mp camera only!
  4. ReapR7
    Froyo Oct 14, 2019
    I replied above.
  5. Horsault
    You know you're on a users' forum, where you're talking to other users like you who're taking on their time to help you, right? So please leave some time and stop demanding immediate answer.
    Like on previous devices (7 series), main camera is 48Mpx whith pixel binding to produce a 12Mpx camera with bigger pixels for enhanced clarity. 4 0.8µm pixels on the captor produce one 1.6µm image pixel. See camera specs on product page.
    Plus, on the T series, you should be able to shoot RAW and movies on all cameras.
  6. ReapR7
    Froyo Oct 17, 2019
    ReapR7 , Oct 17, 2019 :
    Sorry sir, but you still haven't answered my question.
    If the camera app can save a 48mp JPEG then why isn't it saving a 48mp RAW file as well?
    48mp JPEG option disables the pixel binding.
    Similarly the RAW option should also disable the pixel binding and deliver a 48mp RAW file.
    I know that the Sony IMX586 image sensor comes with pixel binding tech called Quad Bayer Array which combines 4 pixel into one and saves a low resolution 12mp picture in low light and a 48mp picture in bright day light.
    I also know that Sony IMX586 can deliver true 48mp RAW data as well by turning off the pixel binding, using which the OnePlus devices are able to produce the full 48mp JPEG files of resolution 6000x8000.
  7. Z1569824375949
    Cupcake Oct 17, 2019
    Z1569824375949 , Oct 17, 2019 :
    48MP Raw picture is all he wants , not each camera's specifications.
    and yes phone doesn't capture 48MP raw image
    ReapR7 likes this.
  8. ReapR7
    Froyo Oct 18, 2019
    ReapR7 , Oct 18, 2019 :
    Yea exactly.. I'm just requesting that they can add a 48mp RAW option in the next update.
    Z1569824375949 likes this.
  9. santi.lo
    Cupcake Nov 14, 2019
    santi.lo , Nov 14, 2019 :
    If I had known this limitación I think i wouldnt have bought the phone. Big issue for me
