5
4g issue and wifi
  1. just4one Donut Jun 27, 2017
    just4one, Jun 27, 2017 :
    i have noticed that my op5 i have h+ or 3g and only a few of time 4g...
    before with the same sim and s7 i was almost every time in 4g...
    also i noticed not good wifi ...
    i should Be afraid of hardware issue or It Can Be solved by software update?
  2. jasonarima Gingerbread Jun 27, 2017
  3. Mr. Vandelay Jelly Bean Jun 27, 2017
    Mr. Vandelay, Jun 27, 2017 :
    No worries, I'm sure it will be fixed in the 4.5.3 update. They are rolling out OxygenOS 4.5.3 OTA for OnePlus 5 globally, here are the changes:
    Bug Fixes:
    • Expanded screenshot display issue
    • Google Translate stutters
    • Wi-Fi occasional drops
    Optimizations:
    • System stability improvements
    • Camera effect and stability enhancements
    • Effects of auto-brightness adjustment
    • Accuracy of data usage statistics
    Rom is available for download at: http://downloads.oneplus.net/oneplus-5/oneplus_5_oxygenos_4.5.3/
    Please feedback in the bug reporting forum here if you encounter any issues: https://forums.oneplus.net/feedback/.
    Source: https://forums.oneplus.net/threads/oxygenos-4-5-3-ota-for-oneplus-5.556197/#post-16382211
  4. TerZz Cupcake Jun 27, 2017
    Mr. Vandelay likes this.
  5. just4one Donut Jun 27, 2017
    Sorry for my bad english what Is career ?
    anywhere this Is a great community
    tanx to everybody from italy
  6. Mr. Vandelay Jelly Bean Jun 27, 2017
    I think he means Wireless Carrier or Mobile Network provider.
  7. just4one Donut Jun 27, 2017
  8. BelowSeaLevel Gingerbread Jun 27, 2017
    BelowSeaLevel, Jun 27, 2017 :
    I have the same issues of no 4G and crappy WiFi (no issue regarding that on One + 3) with the latest patch of 4.5.3.
  9. Yazzypants Donut Jun 27, 2017
    Yazzypants, Jun 27, 2017 :
    I've had similar issues with the phone not wanting to use 4g as well. hopefully this will be fixed soon
  10. sfallon36 Donut Jun 27, 2017
    sfallon36, Jun 27, 2017 :
    I'm on Oxygen 4.5.3 and also have a terrible 4G and wifi connection.
    I'm with Three as the carrier in the UK and haven't had 4G at all since getting the phone.
    On wifi I can get over 200 Mbps download, but upload is very poor, generally less than 3 Mbps, whereas my One+3 gets 12 Mbps on the same network.
    I also bought my wife a One+5 and she has exactly the same issue, upload at 2.3 Mbps, her older One+2 has a better upload speed of 11 Mbps on the same network.
    Not sure why, but the One+5 phone is the common denominator having very poor upload speeds, whilst all other devices including laptops, tablets and PCs are fine.
    roccr likes this.
  11. G_Vincent_GELINET_ctNP Cupcake Jun 27, 2017
  12. elrao Eclair Jun 27, 2017
    elrao, Jun 27, 2017 :
    I've read Wi-Fi connectivity is an issue, I've had three updates already, each mention connectivity improvements
  13. G_Chad_Christenson_OHVF Donut Jun 27, 2017
  14. jasonarima Gingerbread Jun 28, 2017
    jasonarima, Jun 28, 2017 :
    Do you use whole new AT&T SIM and apply by OP5 IMEI?
    If so, this is a known issue and you need to follow following instructions.
    https://forums.oneplus.net/threads/at-t-lte-fix.346493/
    To fix this issue, you need to do the following.
    1. Find a friend who has an AT&T LTE enabled/compatible phone (iPhones have been proven to work).
    2. Get your friend's IMEI number.
    3. Go to a local AT&T store and try to find a useful and knowledgeable assistant.
    4. Replace your OnePlus Two IMEI number with your friend's IMEI number on your AT&T account. Don't worry, nothing will happen to your friend's account or phone. You can have one IMEI number linked to more than one SIM card. It will simply look like your friend's device is linked to two different SIM cards.
    5. Change your Access Point Name (APN) under SIMs Settings on your OnePlus Two to "ATT Phone".
    6. Enjoy LTE.
  15. mschildren Donut Jun 28, 2017
  16. tristaoeast Cupcake Jun 28, 2017
  17. darklajid Donut Jun 28, 2017
    darklajid, Jun 28, 2017 :
    4.5.3 - this smart phone is offline most of the time.
    Wifi just dies and disconnects completely (no, not a router issue..).
    Data seems fine (as in, indicating H+ and a decent signal strength), but the network stalls completely. The phone is offline. Can't use any network services (tested with browser, WhatsApp, FB Messenger). A 'fix' is either jumping back on Wifi (will die again, but .. data will work for a while now) or turning data off and on again.
    And I'm really not a fan of 'try turning it off and on again'. Nor do I like to have a phone that silently won't receive any data anymore. That's basically a brick then. Without any official confirmation that this is a software issue AND high priority, I don't think that the OnePlus 5 is a working smartphone, period.
  18. evacavaca Cupcake Jun 28, 2017
    evacavaca, Jun 28, 2017 :
    Career means your service provider (Vodafone or Movistar)
  19. just4one Donut Jun 28, 2017
    just4one, Jun 28, 2017 :
    i have noticed improvments on wifi...for the mobile nothing...
    i believe that data needs some adjustments
  20. just4one Donut Jun 28, 2017
