2
4g LTE bug cant recieve calls
  1. V1530162429324
    Cupcake Sep 12, 2019
    V1530162429324 , Sep 12, 2019 :
    any one experience bug on 4g LTE mode? if your on 4g network (standby no data activated) you cant recieve calls?? more severe in data on 4g network.. somewhat auto network selection wont work.. using OP6
    tried it somewhat the fone will block the incoming calls or drop the incoming calls event in standby mode
    and yes you cant make a call also.. you cant its just nothing when you try to call some one.. you need to manually select 2g net to make a call
    aayushjain17 and W1537426043677 like this.
  2. W1537426043677
  3. V1530162429324
    so sad.. hope in android 10 they will aggressively tweak network selection based on mobile data used (on/off)
  4. paala
    Cupcake Sep 13, 2019
  5. V1530162429324
    V1530162429324 , Sep 13, 2019 :
    is there a chance oneplus can read this thread.. our phone become media device or actual phone.. never can be both.. hard to be both this time..
  6. paala
    paala , Sep 13, 2019 :
    lot of them having the same issue. OnePlus need to address this issue.
  7. Kytharsis
    Marshmallow Sep 13, 2019
    Kytharsis , Sep 13, 2019 :
    OP never reads these forums.
    drl431 likes this.
