4g won't work on O2 (UK)
  1. Alasdair
    Honeycomb Apr 29, 2014
    Alasdair , Apr 29, 2014 :
    Not sure if anyone else has noticed but the OPO will not work on O2's 4G network in the UK. This is due to O2 only buying from the 800MHz region of the spectrum (band 20 I think).
    Will happily be corrected by OnePlus if the OPO has been updated but the specs documentation (http://oneplus.net/one#specifications) hasn't.
  2. Waterdroid
    Community Veteran Apr 29, 2014
    sp99 and triculious like this.
  3. robert3892
  4. Chinda
    Jelly Bean Apr 29, 2014
    Chinda , Apr 29, 2014 :
    Only Three & EE networks in uk will work with 4G on OnePlus One. The 3G for all networks will be very fast if you cant get 4G.
    nickt likes this.
  5. Alasdair
  6. robert3892
    robert3892 , Apr 29, 2014 :
    By that reasoning it should work if One Plus One has prepared the device properly. Sometimes a software update is all that is needed.
  7. Alasdair
  8. RTrudgian
    Cupcake Apr 29, 2014
    RTrudgian , Apr 29, 2014 :
    And even then, one of Three's bands is Band 20 and I guess that's what they'll have in rural areas? Areas where they're obliged to eventually set up 4G coverage but never had to for 3G?
    For the 4g spectrum sale buyers have to provide coverage to 98% of the population by 2017 but for the 3G auction it only had to be 80%.
  9. HA3AP
    Ice Cream Sandwich Apr 29, 2014
    HA3AP , Apr 29, 2014 :
    Hspa+ is good enough for me and i pay 35$ for unlimited everything
  10. infernowheels
  11. robert3892
    Honeycomb Apr 30, 2014
    robert3892 , Apr 30, 2014 :
    I'll test the device for 4G in the Netherlands if I can manage to get a device in June
  12. junior_patel
    Donut Aug 28, 2014
  13. waynegracias
    Froyo Sep 4, 2014
    waynegracias , Sep 4, 2014 :
    Hii,
    Just wanted to share something with you all about the one plus and 4G in the UK.
    This is not gonna be a software thing, it's the hardware that doesn't support band 20 from a write up I read so sorry guys software update will not fix it.
    If you want 4G on the phone you need to be with three or ee no other provider will be able to support 4G on the one plus.
    Also I can confirm that o2 doesn't support 4G on the one plus as my wife has one and she only gets 3g. I haven't opened mine yet as I still haven't managed to do all the research to make it my primary phone just yet.
    Good luck you guys.
    Post a like if this was helpful.
    shwan, discodude, Thedulli and 4 others like this.
  14. waynegracias
    Froyo Sep 4, 2014
    You will only get 3g on the O2 network in the UK.
  15. mrgoodall0
    Honeycomb Sep 4, 2014
    mrgoodall0 , Sep 4, 2014 :
    I found this out myself when i got my opo two days ago as i am on o2,so now i'm thinking weather to change over to EE or would Three be better ?
  16. molokovellocet9
    Honeycomb Sep 5, 2014
    molokovellocet9 , Sep 5, 2014 :
    Three will generally be cheaper of the two.
    mrgoodall0 likes this.
  17. arniszevri
    Eclair Sep 9, 2014
    arniszevri , Sep 9, 2014 :
    try one of the MVNO's that run on EE eg Asda, Vectone or Virgin
  18. c4chilli
    Ice Cream Sandwich Sep 9, 2014
    c4chilli , Sep 9, 2014 :
    Virgin doesn't support 4g.
    Don't know about the other two you mentioned though.
    arniszevri likes this.
  19. arniszevri
    Eclair Sep 9, 2014
    I was just checking that too and not sure that any of them do currently :(
    EE tariffs are OTT really.
    How good is 3?
  20. waynegracias
    Froyo Sep 20, 2014
    waynegracias , Sep 20, 2014 :
    hiii guys just an update, i posted earlier that 4G dosnt work with o2 but ive noticed something you can activate LTE on the OP and then connect to the network data and speeds seem to be better off, well a little better to when LTE is off and your on network data. someone else try on o2 and confirm if your findings are the same as mine. good luck.
    jugga likes this.
