4
5.0 android
  1. i5xswipe
    Ice Cream Sandwich Apr 15, 2015
    i5xswipe , Apr 15, 2015 :
    Only the first one.
    #41
    noke_93 likes this.
  2. noke_93
    Honeycomb Apr 15, 2015
    noke_93 , Apr 15, 2015 :
    Can you edit notification bar icons? Like in 11s? Just simply add them :)
    #42
  3. ThijsOne+1
    Gingerbread Apr 15, 2015
    ThijsOne+1 , Apr 15, 2015 :
    I have CM12; it is awesome!
    #43
  4. pjwolfs
    Cupcake Apr 15, 2015
    pjwolfs , Apr 15, 2015 :
    That was my first idea, but you cant select the sound toggle option.. It Just isnt there. And i cant get my Phone to vibrate where receiving a text while on vibrate mode...
    #44
  5. Deactivated User
    Apr 15, 2015
    #45
  6. noke_93
    Well I can't help you yet bro,wait untill I get update then I will check... :/
    #46
    pjwolfs likes this.
  7. noke_93
    Ok ty for posting that threads HERE :)
    #47
  8. malidan
    Marshmallow Apr 15, 2015
    malidan , Apr 15, 2015 :
    To a degree that would be dependent on what launches on startup and what is running in the background. With full gapps I would have thought Oxygen would idle higher than Cm.
    #48
    noke_93 likes this.
  9. franck1806
    franck1806 , Apr 15, 2015 :
    You are Right Moke, It will be easier to have OTA instead of doing many process with the risk of doing fault !
    #49
    noke_93 likes this.
  10. malidan
    #50
  11. MamaManka
    #51
    noke_93 likes this.
  12. veratoloz2005
    Lollipop Apr 15, 2015
    #52
    noke_93 likes this.
  13. MamaManka
    MamaManka , Apr 15, 2015 :
    Me neither, but I decided to flash it manually. I was a bit scared that something would go wrong, cuz I was doing it for the first time, but it is so fast end easy :)
    #53
  14. veratoloz2005
    veratoloz2005 , Apr 15, 2015 :
    I am not in a hurry. In the meantime, I am learning what problems L has. :)
    #54
  15. MamaManka
    Yeah I wasn`t to, but lately I had some problems with my phone (Google Service App started draining my battery, screen didn`t turn on immediatley when I unlocked the phone, for a few months I have problems with SMS-phone is sendind duplicate messages sometimes...)
    So I gave it a try, I can still factory reset it :)
    #55
    noke_93 likes this.
  16. noke_93
  17. bobythr
    Donut Apr 15, 2015
    bobythr , Apr 15, 2015 :
    Cm12s is crap...there is some battery draining rapidly, and my phone as rebooted at least 20 times while using it in the last 40-48 hours since installing this pos. Wwith this software cmod and oneplus has become a real low end set. The transition between screens used to be very smooth and nice. Now its the opposite of that. Take your time , imohp, this is a piece of....BEWARE
    #57
  18. MamaManka
    #58
  19. sonjamin
    sonjamin , Apr 15, 2015 :
    Yes, CM singled you out specifically and kept the update from you and ONLY you. No one else that posted they didn't get the update are lying and secretly already have it and you didn't.....
    #59
    t4ww4b likes this.
  20. noke_93
    I knew they were messing around after me..
    #60
