100
ROM [5.1.1][Nightly] Official CM12.1 Nightlies
  1. mmrbest
    Jelly Bean May 20, 2015
    mmrbest , May 20, 2015 :
    Idk about that. There is option for individual app settings, but I don't see launcher/desktop in it :/
    asj0422 likes this.
  2. varunmadhavam
    Cupcake May 20, 2015
    varunmadhavam , May 20, 2015 :
    hi,
    i am running cm12.1 nightlies on mu oneplus one. But facing a peculiar issue. My phone is making random phone call by itself. Anybody facing the same issue..??
  3. amrutprabhu
    Gingerbread May 20, 2015
    amrutprabhu , May 20, 2015 :
    6 times?:eek:
    then something really wrong dude..
    Why don't you update your rom with CyanDelta... I really find it very safe...
    give it a try...
  4. amrutprabhu
    Which nightly?
  5. amrutprabhu
    a) no.... its not available.
    b) What is ED suppose to mean? :)
  6. asj0422
    Honeycomb May 20, 2015
    asj0422 , May 20, 2015 :
    a) rats.
    b) extended desktop
  7. markdj
    Eclair May 20, 2015
    markdj , May 20, 2015 :
    Regarding the power menu, enable developer options and then in there you can turn on the reboot to recovery options and quickboot which can turn on your phone to notify you of an alarm.
  8. ganeshmasare
    ganeshmasare , May 20, 2015 :
    Any source where you checked this info?
  9. robmoh
    Eclair May 20, 2015
    robmoh , May 20, 2015 :
    Sync contacts in Google+ app and turn it off again.
  10. Nkouk88
    Nkouk88 , May 20, 2015 :
    Hello i have two devices(oneplus one) running both of them cm12.1 nightlies (20150518), but i am facing some issues in one device, either if i use trebuchet or nova launcer when i press the homescreen i see a black screen with status bar and the phone doesn't response except power button. After a few minutes comes back with the message " Settings app crashed". This message i got also if the rom is running for first time. I tried to flash the ROM again (full factory reset) but the problem it's stills there. The strange is that the other device is working properly.
  11. vcespon
    vcespon , May 20, 2015 :
    https://www.androidfilehost.com/?fid=95784891001613103
    I suggest flashing it from scratch, using fastboot.
    Go ahead man, I did the same and I'm not having Google or Cyanogen processes at the top of battery ussage. I have screen and 4G radio at the top (as it should be, the hardware, not the software using the battery), and I got almost 7 hours SOT yesterday.
    I have almost no battery drain in standby. That's good enough for me, Android 5.x is not providing me anything better that KitKat.
    Ricbro likes this.
  12. Spannaa
    KitKat May 20, 2015
    Spannaa , May 20, 2015 :
    Yes, it was on Jenkins console output yesterday and I posted the relevant bit of the output in this thread.
  13. adamszostek
    Froyo May 20, 2015
    adamszostek , May 20, 2015 :
    On nightlie from 17th I had ~5h SOT but on latest (18th) something was draining battery so quickly that I managed to have only 3.5h:(
    I also noticed some bug using Apex Launcher (Pro version) - when using built-in power saving mode I have some graphic glitches and and can't see icons in folders. There's just white background and no icons, although if I tap invisible icon it launches app. I also tried Trebuchet launcher and it's same way, but with Google launcher I don't have such issues.
    So is it launcher bug or CM?
    BTW is there an option to add quick setting button to switch between 2G/3G/LTE? I used that in KK and can't find it in L.
  14. prasoonkumarkp
    prasoonkumarkp , May 20, 2015 :
    Hi.. I flashed new cm12.1 nighlies. But now there is no updated theme gallery available. Now I can't change the theme to 'India' or 'yu' where it was available on cm12 officials.
  15. HWAM
    HWAM , May 20, 2015 :
    Where are our Nightly builds :-(
    No 05/19
    No 05/20
    Build process broken?
  16. Tricksodave
    Tricksodave , May 20, 2015 :
    I'd say it'll be out later on today..
    prasoonkumarkp likes this.
  17. imcrazyz
    imcrazyz , May 20, 2015 :
    It's better if they don't rush on their builds, because recent builds are quite unstable in terms of battery life. Give 'em more time to build something better and more stable instead.
    amrutprabhu and HWAM like this.
  18. Spannaa
    KitKat May 20, 2015
    A lot of yesterdays CM12.1 builds were aborted as they timed out after 90 minutes and there are no builds today yet with nothing in the build queue either.
    There's nothing wrong with the sources though - I'm using an unofficial 0519 build and it's running fine.
  19. danzamoyo
    Eclair May 20, 2015
  20. Spannaa
    KitKat May 20, 2015
    No.
