100
ROM [5.1.1][Nightly] Official CM12.1 Nightlies
  1. RoberRamos
    Eclair Jul 31, 2015
    RoberRamos , Jul 31, 2015 :
    Hey, can anyone upload me the mixer_paths.XML
    I didn't backup it and when installing the stereo mod I lost the sound.
    Thanks!
  2. mharis
    Ice Cream Sandwich Jul 31, 2015
    mharis , Jul 31, 2015 :
    Did you come from 11s to the nightly? - Asking as you mentioned you had cleanflashed, and clean flashing is necessary if you're not coming from a previous nightly...
    neokostas1 likes this.
  3. neokostas1
    Gingerbread Jul 31, 2015
    neokostas1 , Jul 31, 2015 :
    can anyone confirm that the 3107 build have issues with this buttons in lock screen and about data (4g) of the phone?
  4. Voodooman
    Froyo Jul 31, 2015
    Voodooman , Jul 31, 2015 :
    I run 12.1 21/7 and I recently noticed that when the alarm is set and the phone is powered off, the phone won't wake up at the time of the alarm. That was happening with official CM. What do you think?
  5. ninjasumit
    ninjasumit , Jul 31, 2015 :
    That's a CM11S exclusive feature. You won't have it on other custom ROMs.
    Voodooman likes this.
  6. urgali
    Froyo Jul 31, 2015
    urgali , Jul 31, 2015 :
    For everyone that may have had this problem, i can confirm that using twrp 2.8.6.0.6 (but probably the normal 2.8.6.0 is fine too) resolves the issue, and i even noticed an increase in battery life.
    Ricbro likes this.
  7. Trusconi
    Jelly Bean Jul 31, 2015
    mharis likes this.
  8. blujadajhdja
    Ice Cream Sandwich Aug 1, 2015
  9. Ricbro
    Ricbro , Aug 1, 2015 :
    Battery life....
    I run completely stock everything and adaptive brightness half way.
    I'm using the 29th July build (haven't seen a reason to flash a later build yet)
    This is mainly on WiFi but I did stream some music on deezer whilst driving today on 3g.
    Screenshot_2015-08-01-00-32-21.png Screenshot_2015-08-01-00-32-32.png Screenshot_2015-08-01-00-33-07.png
  10. imcrazyz
    Gingerbread Aug 1, 2015
    imcrazyz , Aug 1, 2015 :
    I've got this calendar storage on the top list of wakeup triggers in wakelock detector.
    Just asking whether I can use privacy guard to turn off wake up, keep awake, read calendar and modify calendar? I'm afraid of FCs.
  11. gauravbjain
    Donut Aug 1, 2015
    gauravbjain , Aug 1, 2015 :
    I am on 7/28 build and have this bug with clock battery drain. Can someone help with this ? Thanks.
  12. urgali
    Froyo Aug 1, 2015
    urgali , Aug 1, 2015 :
    I usually use privacy guard to stop wake ups on almost every apps, cLock and calendar too. (I don't use any alarm btw, so i don't know if it stops your clock from working).
    Anyway, i've got a question: is it worth to "upgrade" to f2sf format instead of ext4?
  13. Roaringriku786
    Froyo Aug 1, 2015
    Roaringriku786 , Aug 1, 2015 :
    What do you guys get on your antutu benchmark. I am getting around 48k which is lower than I got on the Factory CM12. Any suggestion?
  14. Spannaa
    KitKat Aug 1, 2015
    Spannaa , Aug 1, 2015 :
    Benchmarks are a waste of time.
    Don't do benchmarks or go back to CM OS12
    AntMunny, Ricbro and bkbkjbb like this.
  15. bkbkjbb
    Honeycomb Aug 1, 2015
    bkbkjbb , Aug 1, 2015 :
    ^^^ Bingo!
    So tired of hearing all this meaningless benchmark crap. It means absolutely nothing and doesn't tell you anything about how the phone actually feels. People be number crazy.
  16. imcrazyz
    Gingerbread Aug 2, 2015
  17. imcrazyz
    sn809 and AntMunny like this.
  18. biltoad
    Honeycomb Aug 2, 2015
  19. Samavedula
  20. robthorley
    Ice Cream Sandwich Aug 2, 2015
    robthorley , Aug 2, 2015 :
    I've noticed that I lose root every flash. Should I add SuperSU to the list of files to flash in CyanDelta?
