40
ROM [5.1.1] Unofficial CyanogenMod 12.1 with CAF 3.4.0 kernel
  1. 69gm
    Jelly Bean Sep 10, 2015
    69gm , Sep 10, 2015 :
    Glad to hear it! :)
  2. ddlittlejohn
    Honeycomb Sep 11, 2015
    ddlittlejohn , Sep 11, 2015 :
    Thanks for clarifying - will give the 20150910_STABLE in the updater for a spin ;)
  3. 69gm
    Jelly Bean Sep 11, 2015
    69gm , Sep 11, 2015 :
    Attention everyone! We've come across some problems and @Sultanxda is working on a fix. You may want to hold off on updating if you haven't done so.
    Those that did and run into problems, like I did, please wait for Sultan's next build. It will be coming very soon. He is also continuing to test yet another modem for the phone so it's an ongoing thing.
    Evokkimus and ddlittlejohn like this.
  4. kale566
    kale566 , Sep 11, 2015 :
    What's the problem????
  5. bigab24
  6. 69gm
    Many have reported instability issues. I, myself, had a random reboot directly connected with the modem. Although there are those that have had great success with this modem, there are too many stability issues that can't be ignored and a new build is in the works.
    ddlittlejohn likes this.
  7. ddlittlejohn
  8. siva-kumar
    Gingerbread Sep 11, 2015
    siva-kumar , Sep 11, 2015 :
    I coming from another stable build (9/6) so I didn't clean flash.
    Also I am using multirom, so wasn't sure if I can use CM updater to do the flashing from OS, as this is a secondary ROM.
    I even tried by downgrading TWRP from 2.8.7 to 2.8.6.1. No luck there also
    Will wait for the next build.
  9. kale566
    Heeeeelp Google play service is crashing as we speak continues what do I do hurry before I break the phone hurrrrrrr
  10. kale566
    I finnaly fixed it by reflashing gapps on top of the one which corrupted everything but now where great
  11. 69gm
    Evokkimus likes this.
  12. kale566
    Here we go waiting
  13. Evokkimus
    KitKat Sep 11, 2015
    Evokkimus , Sep 11, 2015 :
    Will wait. I haven't had any problems at all either.
    Edit: Noticed the new build is up, will flash right away.
  14. Evokkimus
    KitKat Sep 11, 2015
    There is this one bug that's been on few older builds too. Basically the navigation bar animations and all the lollipop "circle" animations (like on quick settings panel) start being choppy. Overall performance is good but the animations have a low framerate. Reboot fixes it though.
  15. rupamkonar
    Cupcake Sep 11, 2015
  16. sirovai
    Eclair Sep 11, 2015
    sirovai , Sep 11, 2015 :
    but...why?
  17. helloworld08
    helloworld08 , Sep 11, 2015 :
    there seems to be a bug where I am unable to turn off the flashlight, i would need to reboot the phone to turn off the flashlight sometimes.
    This only happens after i plug the phone to charge, drawing V will not turn off and also the flashlight button doesn't work as well.
  18. Thephoneofphones
    Thephoneofphones , Sep 11, 2015 :
    Hey guys,
    Just wanted to share that I am back on the stable 9/10 rom and its running like a champ. Have a few xposed modules running as well. Amplify, Greenify, MobileActiveRadioFix, and YouTubeAdAway. I switched last week from XenonHD>to Pacman>Sultanxda's and really am a believer. I truly think this is the best rom for the OPO. It is very stable and miserly on battery.
    Great work @Sultanxda
    Cheers and happy flashing!
    Oh and its Friday!!!
    :D
  19. Thephoneofphones
    It is probably the best camera software for the OPO. You should reconsider...
    Evokkimus and sirovai like this.
  20. Sultanxda
    Recognized developer Recognized Developer Sep 11, 2015
    Sultanxda , Sep 11, 2015 :
    This is caused by face unlock. Turning on the flashlight, putting your phone to sleep, then waking your phone up while face unlock is enabled is what causes this. At the moment, I'm not sure if this is specific to the camera HAL I'm using.
