40
ROM [5.1.1] Unofficial CyanogenMod 12.1 with CAF 3.4.0 kernel
  1. @punto
    Ice Cream Sandwich Oct 12, 2015
    @punto , Oct 12, 2015 :
    Same problem here[/QUOTE]
    flash xposed-v75-sdk22-arm.zip
    LastLeg likes this.
  2. resporival
    Honeycomb Oct 12, 2015
    resporival , Oct 12, 2015 :
    Flash with latest...v75.. No bootloop
    mymutatedmind likes this.
  3. tawhid111
    Gingerbread Oct 12, 2015
    tawhid111 , Oct 12, 2015 :
    in call volumes are too low i can barely hear the people on the other end mic volumes seems to be better in this one than original 12.1 guys really need this fix the call quality is fine when on speak
    any suggestions ?
  4. mycheetah
    Eclair Oct 12, 2015
    mycheetah , Oct 12, 2015 :
    On latest 11 October version, flashed Xposed v75-sdk22-arm.zip, no bootloop and everything is working flawlessly.
  5. Evokkimus
    KitKat Oct 12, 2015
    Evokkimus , Oct 12, 2015 :
    One reason why PAC should use Sultan's CAF :p
  6. @punto
    should i use ak caf kernel on sultans rom or the default kernel is better?
  7. Evokkimus
    KitKat Oct 12, 2015
    Well I have only used stock CAF, and in ny opinion it is super good. I have had absolutely 0 issues with it and performance and battery life is top notch.
    @punto likes this.
  8. ddlittlejohn
    ddlittlejohn , Oct 12, 2015 :
    From what my experiences tell me, stick with default. I had way too many issues with AK's kernel on this ROM.
    @punto likes this.
  9. Evokkimus
    KitKat Oct 12, 2015
    I'll take my comment back. Unofficial Euphoria doesn't have CG at the moment. The dev is not sure though what happens when Official Euphoria updates.
  10. @punto
    thnxxx...
  11. @punto
    thnxxx
  12. @punto
    also anyone of u guys using any greenify or amplify or deep sleep thingies?
  13. bhavinvis
  14. Evokkimus
    KitKat Oct 12, 2015
    I'm only using the paid version of Amplify. No other battery saving apps.
  15. 69gm
    Jelly Bean Oct 12, 2015
    69gm , Oct 12, 2015 :
    This is, of course, a personal preference and YMMV, but I used to use these things...then decided to simply things and not use anything. I don't think I've seen a significant difference...so I've never gone back to using those "thingies". Sultan's ROM seems like it handles things very nicely.
    @punto and Evokkimus like this.
  16. 69gm
    Hmm, I hear everyone fine so far...sometimes it's too loud!
  17. Evokkimus
    KitKat Oct 12, 2015
    I just kind of "left it on" from PAC-ROM, which had better battery life due to Amplify. Not so sure about how it works on Sultan :D
  18. Psk.it
    KitKat Oct 12, 2015
    Psk.it , Oct 12, 2015 :
    someone can suggest a version of xposed framework running on the yesterday build?
  19. sirovai
    Eclair Oct 12, 2015
    sirovai , Oct 12, 2015 :
    The same here
  20. 69gm
    Just taking a little poll...in the latest build, Sultan removed Fluence since it seemed like it was causing so much trouble for people. Do you notice if it's been helping when you're on a phone call? It's strictly a CM thing so other ROMs like Oxygen never had it, FYI.
