255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. pluscat
    Gingerbread Aug 17, 2015
  2. Naveen_AN
    Froyo Aug 17, 2015
    Naveen_AN , Aug 17, 2015 :
    I do have it. But its not blocking it.. Ad appears every 30mins and stays for 30 secs.
  3. Naveen_AN
    Froyo Aug 17, 2015
    Thanks a lot ! Adaway will work?
  4. rTn
    Donut Aug 17, 2015
    rTn , Aug 17, 2015 :
    yea but don't like nightlies... i thought the topicstarter always noted the best release to install at this moment. Can't find it for now...
  5. werdnoynek
    Donut Aug 17, 2015
    werdnoynek , Aug 17, 2015 :
    o_O Adaway is not blocked. I have it installed (have had it installed since anti-piracy was implemented) and it's working as intended on the 08/17 release. Nice try though...
    girishb86 likes this.
  6. Reloaded
    Honeycomb Aug 17, 2015
    Reloaded , Aug 17, 2015 :
    I have just got warranty on my phone and got a new replacement and I want an update. Is 5.1 Exodus (especially the august builds) worth installing? Because 5.0 was amazing especially battery life but I heard multiple times that the 5.1 builds have crappy battery life. So if someone could share some screenshots of battery that would be awesome!!!
  7. avinashadvani
    Jelly Bean Aug 17, 2015
    avinashadvani , Aug 17, 2015 :
    5.1 battery not s great but good enough. Couple of builds around 10-12 had issues but they are sorted and work as stable as any other ROM out there.
    Don't follow advice given by cupcake accounts with 15 messages created just to diss the ROM and the devs.
    This is a great ROM if you want to flash a ROM and try this is the one flash the latest build if you are not affected by piracy issues.
    Flash the 22 July build if you use pirated Apps. Your choice entirely.:cool:
  8. Reloaded
    Thank you for the update; I won't install it. What 5.1 Rom + Kernel config would you recommend for battery life and stability (slim saber etc.) as I have a private build of cm 11S that came stock with the new replacement and its battery life is awesome. 6-7 hrs SOT and amazing stability + benchmark get rocked. The only drawback that its a 4.4.4 build and not a 5.1 Lollipop so I want a 5.1 ROM (and kernel if so) with 6-7 hrs of SOT and amazing performance. Also what profile on the AK kernel?
    Thanks for handling my trickiness as I was a flashaholic on my old OPO (and hard bricked twice) but now I just want to root and upgrade to an amazing ROM with 5.1 and stay with it!
  9. Reloaded
    Thanks i do use pirated apps. I just want a stable good battery life ROM (see post above) as I was a flashaholic before (and hard bricked twice) but now I got a new replacement (screen issue) I want a 5.1 ROM with 6-7 hrs of SOT and the best performance because (as I said in the post above)
    "I have a private build of cm 11S that came stock with the new replacement and its battery life is awesome. 6-7 hrs SOT and amazing stability + benchmark get rocked. The only drawback that its a 4.4.4 build and not a 5.1 Lollipop so I want a 5.1 ROM (and kernel if so) with 6-7 hrs of SOT and amazing performance." So yea, it it really worth it and does it have the two things i need. Thanks for your help bro!;)
    avinashadvani likes this.
  10. avinashadvani
    Alrighty good luck then
    I have got 7 hours sot on this ROM with just stock setup no time wasting on tweaking a setup. I have posted screen shots quite a few times. 6 hours is my daily standard with my usage. Just saying :D:D
    There's an apk by someone to remove the anti piracy also if that's an issue
    Anyway good luck:D
  11. Reloaded
    Could you post the screen shot, I cant find it. Also can you post the apk as well if that's not too much hassle :p
  12. puppy21love
    Eclair Aug 17, 2015
    puppy21love , Aug 17, 2015 :
    6 hours is the norm and you are happy? Stock yields 5.5 hours. I can see they really have your battery's back.
    Frankrizzo likes this.
  13. avinashadvani
    You will find links to that in a few signatures of the posters here. Just do a simple search there is a thread dedicated to it too.
    Screenshots have been posted a while back when I do another cycle ill post it
  14. red5pade
    red5pade , Aug 17, 2015 :
    well i give it a try but it used too much ram and would start lagging when i tried to play fallout. had to go back to the other roms. glad yall added the warning about the feature though.
  15. puppy21love
    Eclair Aug 17, 2015
    About time. Now people can choose if they want this feature. Mind posting some screenshots of the warning?
    Vagante and Frankrizzo like this.
  16. red5pade
    its on their website so im told and then next build will have a popup i think. i was just told and i believe them cause its the internet
  17. Stroky750
    Ice Cream Sandwich Aug 17, 2015
  18. puppy21love
    Eclair Aug 17, 2015
    I just downloaded the files using the link on the first post. I got no warning.
  19. nilatacb
    nilatacb , Aug 17, 2015 :
    Personally I'm on 2107 build. No issues so far. I see no reason to upgrade for now. Recently I added AK kernel and a few of styloking's V11 tweaks. Very happy with battery life.
    Rolodex likes this.
  20. Terrawatt
    Donut Aug 17, 2015
    Terrawatt , Aug 17, 2015 :
    Amazing ROM. The nav bar is fantastic, the battery life awsome. Feels like a new phone (20150818).
