255
ROM
[5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. lilzad Honeycomb Sep 27, 2015
    lilzad, Sep 27, 2015 :
    i had an issue where my screen kept turning on i dont know if it is the same as yours but it was fixed when i switched off ambient display. try that hope it helps
    akiles likes this.
  2. tpylvane Donut Sep 27, 2015
    tpylvane, Sep 27, 2015 :
    Is anybody else experiencing Chrome crashes on lates build? For me the 21/9 and the latest 25/9 Chrome works just fine for a two days or so but out of nowhere the app freezes in the midle of browsing. And after that fatal first freeze/crash the app doesn´t even open. It just crashes as soon as I open it. Even clearing the app data and cache does not help. The only thing making Chrome useable again is to boot to recovery and wibe cache and dalvik cache. Also why is watching videos from the browser experiencig much more lagging than what I had using OxygenOs. I still think Exodus is great but I would like to get these minor bugs fixed.
  3. RajaMu Jelly Bean Sep 27, 2015
    RajaMu, Sep 27, 2015 :
    Thanks for reporting will have a check on this issue.. but for me no problems with chrome on latest sources..
    Tomorrows update, we have done several kernel changes, you can see some battery performance improvements .. well you can confirm on the same after you upgrade.
    paulo111, Stroky750 and winstonsmith like this.
  4. RajaMu Jelly Bean Sep 27, 2015
    @♛GR♛
    As said by Stepa , please try with flashing firmware before flashing rom which is mentioned on initial post of this thread.
    @Stepa thank you :)
  5. sa00044 Gingerbread Sep 27, 2015
    sa00044, Sep 27, 2015 :
    BE ADVISED!
    I have just run an Antivirus scan with 360 Security on my phone and it turns out that the Unified Mail app that is installed with the 25 September version is infected with a trojan called "Banker Trojan".
    I have uninstalled the app and run the scan again and it turned out clean.
  6. jstepa KitKat Sep 27, 2015
    jstepa, Sep 27, 2015 :
    This just takes the cake, first malware and now trojans on every install.
    People, run like hell to other ROM's
  7. RajaMu Jelly Bean Sep 27, 2015
    Actually unified email app is CM owned testing app and unfortunately i got added in merge
    Well later I have removed so tomorrows build will not reinstall this app.
    Sorry for inconvenience ! nothing to worry about that app its simply a testing app which got automated test methods inside it.
    Sorry for inconvenience as I explained above its a CMmod app. appreciated if you understand !
    If you are on exodus please remove the app from system app remover.
    Thanks !
  8. cahz1307 Cupcake Sep 27, 2015
    cahz1307, Sep 27, 2015 :
    Is the call recording feature gone on 09/21 build?
    AppLock is not working for me also
  9. vebs_2014 Eclair Sep 27, 2015
    vebs_2014, Sep 27, 2015 :
    i installed Multirom on 7 sept build but when I try to add another rom i.e. cm-12.1-YOG4P-20150925-STABLE-Sultan-bacon; it gives me failure message in TWRP.
    Error Executing updater binary in zip...Do I need to flash firmware too before adding another rom? Exodus is my Primary rom
  10. Maxincredible52 Froyo Sep 28, 2015
    Maxincredible52, Sep 28, 2015 :
    download server is slow as hell... 70kbytes/sec? really?
    that and also content guard are the reasons why i will change to another ROM now, bye guys ;)
  11. RajaMu Jelly Bean Sep 28, 2015
    RajaMu, Sep 28, 2015 :
    OK cool enjoy :).. Thanks for trying Exodus !
  12. RajaMu Jelly Bean Sep 28, 2015
    Can please share the twrp screenshot ?
  13. akiles Froyo Sep 28, 2015
    akiles, Sep 28, 2015 :
    hey, @raja.m any news on how to get rid of the Mobile Radio Active wakelock?? This is the only thing that is making me consider going back to kitkat since it is my main battery drainer when on LTE.
    Thanks in advance for your reply.
  14. Tricky Ice Cream Sandwich Sep 28, 2015
    akiles likes this.
  15. vebs_2014 Eclair Sep 28, 2015
  16. AllPr0 Gingerbread Sep 28, 2015
    vebs_2014 likes this.
  17. vebs_2014 Eclair Sep 28, 2015
    vebs_2014, Sep 28, 2015 :
    After flashing that firmware..now I able to install second rom.
  18. vebs_2014 Eclair Sep 28, 2015
    Love the camera..snapdrogon :)
    better I use it without google apps integration i.e. only for call/ sms/ and mails :)
    dadaus likes this.
  19. vebs_2014 Eclair Sep 28, 2015
    Whats new features or improvement in latest build? anybody tested?
    I am downloading
  20. Stroky750 Ice Cream Sandwich Sep 28, 2015
    Stroky750, Sep 28, 2015 :
    Runs really great, had no time to test it, so far everything seems fine like usual!
    minecabla and vebs_2014 like this.
