255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. varunaasuri
    Gingerbread Oct 2, 2015
    varunaasuri , Oct 2, 2015 :
    yes.. so far every single rom ive changed to ive only done the factory reset option... never cleared the data partition
  2. jstepa
    KitKat Oct 2, 2015
  3. varunaasuri
    im using philz recovery (cwm) will that be ok? and is there a way to flash twrp over philz?
  4. jstepa
    KitKat Oct 2, 2015
    jstepa , Oct 2, 2015 :
    I have newer tried that, so don't know...
  5. winstonsmith
    Honeycomb Oct 2, 2015
    winstonsmith , Oct 2, 2015 :
    Yes, well i had little close to none battery drain when idle on 30th build. Is it the same now?
  6. varunaasuri
    do you know if its possible to flash twrp over philz? im not sure if i can just do a fastboot command with twrp and if it will write over philz
  7. jstepa
    KitKat Oct 2, 2015
    Like I said, newer used that, but in TWRP you can flash another version within TWRP itself.
    So can't promise it'll work, TWRP images you can find: https://dl.twrp.me/bacon/
    varunaasuri likes this.
  8. winstonsmith
    Yes, fastboot should be the way to do it... If it leaves you with no recovery at all and no possible way to boot to your rom, then just flash a full cyanogen img. (Been there done that)..
  9. talktome322
    talktome322 , Oct 2, 2015 :
    I have installed it at 8am . That time my phone battery was 27% now it is 17%. Later I I installed Vanir ROM. So I fell battery is better in this build. More can say after a day's use.
  10. varunaasuri
    Sooo after a lot of searching around... I decided to go back to the XDA Page of Sultan's ROM and he mentioned the TZ Trustzone thing in there. Problem solved.
    Thanks to everyone who pitched in. I will never leave my OnePlus simply due to the amazing community. And @jstepa you were right about the firmware.
    RajaMu and jstepa like this.
  11. RajaMu
    Jelly Bean Oct 2, 2015
    RajaMu , Oct 2, 2015 :
    Well as we said already it's because of cm reorganization of oppo and oneplus folder device related stuff you need to reflash firmware mentioned in initial thread. There after you can install any cm based ROM.
  12. AllPr0
    AllPr0 , Oct 2, 2015 :
    My google now search is lagging so much that it's almost unusable. Any suggestions?
  13. AllPr0
    I need it because I use it as quick search by long pressing home...
  14. ANewSubject
    Froyo Oct 2, 2015
    ANewSubject , Oct 2, 2015 :
    Need some help, after the 9/30/2015 update I cannot update my phone. I tried downloading from my phone then my computer, neither worked. Then I tried a different ROM and it didn't work either. Help?
  15. winstonsmith
    Clear its cache, turn off/on. Reboot wipe cache/dalvik. Uninstall reinstall. Lot of options
  16. AllPr0
    flash the firmware found in the first page of this thread
  17. AllPr0
    I think I have done all of this options, maybe it's because I need to do a clean flash, but I'm waiting exodus 6.0 to do that
  18. AllPr0
    I think I solved, It was an app that changed the read ahead of the sd from 512kb to 1024kb, I uninstalled it and restored stock values and now google now search is working normally :)
    winstonsmith likes this.
  19. varunaasuri
    what I actually did was factory reset and flash the newest CM 12.1 Nightly which has the new firmware, and then without rebooting flashed Sultan's ROM on top of that. But yes, the reason for flashing that was to get the new firmware. I was really freaking out for a second haha
    jstepa likes this.
  20. ermexiro
