255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. nilatacb
    Honeycomb Oct 27, 2015
    rkiwtir and blindX like this.
  2. ermexiro
    Gingerbread Oct 27, 2015
    blindX likes this.
  3. SATHIZKR
    Cupcake Oct 27, 2015
    SATHIZKR , Oct 27, 2015 :
    The Bug is with latest build google play services AKA gms service.
    Simply disable the Android Device Manager and Go to Apps--> All-->>google play services-->>Uninstall updates.
    And download the previous stable build from http://www.apkmirror.com/apk/google-inc/google-play-services/ and double check with compatible OS version 5.0.2/5.1.1 .
    Install it and enjoy.
    It works for me am on 5.0.2 and buggie play services build :
    Google Play services 8.3.00 (2353383-238) latest
    Google Play services 8.3.00 (2353383-236)Stable build. ;):):D
  4. hassaan7
    hassaan7 , Oct 27, 2015 :
    The Google play services error is on cm12 too. Not only while opening maps and using GPS. Also when I plug in my device. Don't know what correlation is that
  5. stijnie2210
    Ice Cream Sandwich Oct 27, 2015
    stijnie2210 , Oct 27, 2015 :
    Opening Google now is laggy and slow as hell on Exodus. Experience has been getting slightly worse.
    Evokkimus likes this.
  6. schenksander
    Froyo Oct 27, 2015
    schenksander , Oct 27, 2015 :
    I'm about to do a clean install, because my screen rotation broke already a month ago and now it is getting anoying. Also, battery life could do significantly better.
    My question is: what is the most stable, smooth, battery friendly Exodus release ATM?
    I read some good things about 0709 but that's already a while ago
  7. akiles
    Froyo Oct 27, 2015
    akiles , Oct 27, 2015 :
    M didn't fix the RMA bug??? Damn, I guess I will have to go back to kit kat
  8. Nicolas_g134
    Nicolas_g134 , Oct 27, 2015 :
    Why does the phone vibrate when you DDTW? :/ can you turn this off?
    EDIT: I found it but when I turn it off, and leave the settings or lock my screen, it automatically puts itself back on :eek:
  9. henkmeuter
    henkmeuter , Oct 27, 2015 :
    Latest builds are stable and have nice battery, I'm on 1021 build with pico open gapps. In changelog I see some kernel changes for oneplus. Is this for the oneplus one too? @TheCrazyLex if so I think I'm gonna try that one, what is included in the changes? Backup system now cause it's rocking!
    Edit @schenksander wrong post replied
    akiles, TheCrazyLex and minecabla like this.
  10. tfae
    tfae , Oct 27, 2015 :
    It's a CyanogenMod bug.
    Will be fixed in the next Nightly: http://review.cyanogenmod.org/#/c/114991/
    Nicolas_g134 likes this.
  11. Amitchawla20
    Froyo Oct 28, 2015
    Amitchawla20 , Oct 28, 2015 :
    what's wrong with the new builds? just flashed 26th built and phone is hanged like dummy, no response at all. also in recovery can't see anything its all blurred like if screen is broken.
    denisk and Evokkimus like this.
  12. Adidz
    Gingerbread Oct 28, 2015
    Adidz , Oct 28, 2015 :
    If you are doing a clean install why don't you try different roms then? If you want stability and smoothness then I'd recommend sultans 12.1 CAF rom. No issues there..
    Rowios and Evokkimus like this.
  13. Nicolas_g134
    Nicolas_g134 , Oct 28, 2015 :
    Any way to disable content guard on exodus? I have the xposed module but I get a parsing error anyway...
  14. Evokkimus
    KitKat Oct 28, 2015
    Evokkimus , Oct 28, 2015 :
    They are integrating it even deeper.
    JayminVyas and @punto like this.
  15. loco-cork
    loco-cork , Oct 28, 2015 :
    Exodus ROM with Oxygen firmware improved the battery big time. Also the network signal seems to be better now and not dropping like it was on CM firmware.
  16. @punto
    Ice Cream Sandwich Oct 28, 2015
    @punto , Oct 28, 2015 :
    sorcery
  17. rkiwtir
    pikota likes this.
  18. AllPr0
  19. rkiwtir
    rkiwtir , Oct 28, 2015 :
    Sometimes it happens like, few times the notification bar becomes bigger on landscape mode etc. Reboot fixes it. (Temporarily) But what's causing it?
  20. erospolonini
    Froyo Oct 28, 2015
