255
ROM
[5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. return.of.octobot Jelly Bean Apr 12, 2015
    return.of.octobot, Apr 12, 2015 :
    So guys, my QuickSettings Pulldown keeps disappearing on the 4.11/4.12 builds, Reboot doesn't fix, I've had to reflash twice to get it back, only for it to inevitably disappear again.. super fun
  2. rguarascia Jelly Bean Apr 12, 2015
    rguarascia, Apr 12, 2015 :
    I've updated my recovery but still get the same error while trying OTA updates. Any suggestions? Screenshot_2015-04-12-15-05-08.png
  3. TBou Froyo Apr 12, 2015
    TBou, Apr 12, 2015 :
    Is there any way of putting of name of exodus on the status bar?:s
    Is a really good ROM !
  4. Psk.it KitKat Apr 12, 2015
    Psk.it, Apr 12, 2015 :
    in the status bar settings, disable greetings
    try re-flashing the firmware, and check the md5 to be sure the file has been downloaded correctly
    TBou likes this.
  5. return.of.octobot Jelly Bean Apr 12, 2015
    What do you mean? By default the statusbar displays "EXODUS ANDROID" every time you unlock your device. If you want it there permanently, you'd have to use something like Android Theme Engine.
    BTW as far as the Disappearing Quick Settings I mentioned above on 4.11/4.12 builds, it's still happening but I did figure out that I can get it back my messing with the QuickSettings layout in Interface Settings, changing something random, and then reverting back to default. Still kind of annoying though.
  6. TBou Froyo Apr 12, 2015
    My question was solved. Thanks ! And thanks to @Psk.it !
  7. striker280 Gingerbread Apr 12, 2015
  8. Marino63 Cupcake Apr 13, 2015
  9. Marino63 Cupcake Apr 13, 2015
  10. DaxNagtegaal Marshmallow Apr 13, 2015
    DaxNagtegaal, Apr 13, 2015 :
    Don't use Franco kernel use the stock Exodus kernel
    bestlands likes this.
  11. 69gm Jelly Bean Apr 13, 2015
    69gm, Apr 13, 2015 :
    +1
    DaxNagtegaal likes this.
  12. TimeFlies7 Ice Cream Sandwich Apr 13, 2015
  13. reyscott1968 Jelly Bean Apr 13, 2015
  14. 69gm Jelly Bean Apr 13, 2015
    I believe you will have to have a nandroid backup of your CM11S. Once you restore that backup, flash the correct modem. Then you should receive the OTA of 12S.
  15. TimeFlies7 Ice Cream Sandwich Apr 13, 2015
    TimeFlies7, Apr 13, 2015 :
    so i just need to restore from TWRP ? and i need to wipe everything b4 restoring back to CM11s rite?
  16. 69gm Jelly Bean Apr 13, 2015
    Yes.
  17. TimeFlies7 Ice Cream Sandwich Apr 13, 2015
  18. bhoopesh Donut Apr 13, 2015
  19. Vinod2 Cupcake Apr 13, 2015
    Vinod2, Apr 13, 2015 :
    I have been using this rom for a few weeks now and i think this rom is amazing. I also tried it with the franco kernel but i did not notice any more SOT though. The benchmarks with the franco kernel were also a lot less than with the original kernel for me. so i changed it back to the original.
    ArdeXxX likes this.
  20. neviusnc Honeycomb Apr 13, 2015
    neviusnc, Apr 13, 2015 :
    Just installed, thank you soo much for you guys' hard work
    RajaMu likes this.
