255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. MartinoPT
    Honeycomb May 21, 2015
    MartinoPT , May 21, 2015 :
    So I was getting just about 3h30m battery life for a week with this ROM, but then I've made a couple of fixes here in this thread https://forums.oneplus.net/threads/combined-battery-drain-issues-thread.286369/ and now I've been getting 5h30/6h these last 2 days (heavy usage, wi-fi/data always on), from 100 to 5%, which is basicly 40% improvement, which is GREAT! The rom itself looks more stable and fluid and NOW, yes, I am loving it!
    What I did:
    - wakelock-fix.apk
    - fix #1 (already had that one)
    - fix #3
    - fix #6
    - fix #8 (upgraded google play services version to the last build)
    Note: still have the sense that it's improvable, but 5h30 SOT is great already!
    The187Hitman and Nicolas_g134 like this.
  2. tienpham3221
    Gingerbread May 22, 2015
    tienpham3221 , May 22, 2015 :
    So far euphoria has been working pretty well. Of course it doesn't have all of the extra rom features as exodus, but it's sufficient enough. There aren't many battery draining services/apps but overall the battery doesn't seem like to hold up super well. I consistently get about 5-6 hours SOT. I think I'm gonna stick to euphoria over exodus
  3. return.of.octobot
    Jelly Bean May 22, 2015
    return.of.octobot , May 22, 2015 :
    Really jonesing for 5.1, not going to lie it's a bit disheartening to hear the devs say that they 'don't feel like releasing it to the public yet'.
  4. fgaurano
    Ice Cream Sandwich May 22, 2015
    fgaurano , May 22, 2015 :
    Rotate your orientation to landscape and viola!
  5. rrohanjs
    rrohanjs , May 22, 2015 :
    hey, i dont know if you guys take feature requests but i'll still listen them anwyays, you can ignore them if you want :p
    1. sync tile
    2. 2g/3g tile
    3. a tile that will pop up the volume sliders
  6. tahir2676
  7. red5pade
    Honeycomb May 22, 2015
    red5pade , May 22, 2015 :
    Might try hangouts till you get it fixed
  8. Evokkimus
    KitKat May 22, 2015
    Evokkimus , May 22, 2015 :
    Thanks for the advice :D
  9. avinashadvani
    avinashadvani , May 22, 2015 :
    I been getting this unfortunately Google plasty services has stopped pop up for a while and seems to happen more frequently.
    Any idea what causes this what should I look for
    Evokkimus likes this.
  10. dansoh
    Eclair May 22, 2015
    dansoh , May 22, 2015 :
    My Friend, I think you and I have the same bug... I also check a few times a day. My F5 key is worn off from refreshing hehehe.
    ravager12 likes this.
  11. dansoh
    Eclair May 22, 2015
    Use older version of skype 4.9.0.45564, has been working for me.
    tahir2676 likes this.
  12. Nicolas_g134
    Nicolas_g134 , May 22, 2015 :
    Yes I know but since Xposed is still in alpha phase and I don't really know much about it, I'm a bit reserved :)
  13. sayso
    sayso , May 22, 2015 :
    Getting a bug with kindle not downloading any of my books then stopping working anyone have any ideas, i have done all the usuals, at the moment it looks like i might have to side load my books on!
  14. Evokkimus
    KitKat May 22, 2015
    Do not click this link, there is nothing more suspicious than an adfly link with a different language, tell me i've been there :D
    edit: also the guy is a mother f**ing cupcake
  15. Evokkimus
    KitKat May 22, 2015
    Shouldn't you post your kindle problems on its own thread? Or rather, search google? A thread about a famous oneplus rom doesn't really mention kindle.
  16. The187Hitman
    The187Hitman , May 22, 2015 :
    ME TOO!
  17. ArdeXxX
    ArdeXxX , May 22, 2015 :
    Yeah well, the Kindle app not working (because of the app) with Exodus has been a known issue for months. Might not be a bad idea to include a list of these known issues in the first post(?)
  18. sayso
    Thanks for your help looks like I will flash back to a rom where kindle does work, Validus was running well but will probably give blisspop with boefela another shot.
  19. Evokkimus
    KitKat May 22, 2015
    Ooh, i thought he ment flashing books to amazon kindle or something, that got me confused, my bad :D
  20. sayso
    why would i be posting on here talking about kindle if it wasn't relevant to the topic!!! anyway have flashed Pac with franco kernal for the moment, couldn't see the Kindle problem in the ROM notes saw a mention of Skype but i usually use my S6 which is on stock for that.
