255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. Henry80
    Ice Cream Sandwich Jun 2, 2015
    Henry80 , Jun 2, 2015 :
    Yep, but zn4jp3 asked a few pages ago if this new build of the ROM has or hasn't the bug:
    I just felt 'twas polite to report an answer.
    I know it's google fault, but I still hope some dev might find a workaround for this: if you look at the AOSP issue tracker page, it's among the top 5 bugs that have been starred more and still google isn't fixing it: so that's why we are putting our hope in some skilled developers' hands.
    maria teresa70 and Evokkimus like this.
  2. Evokkimus
    KitKat Jun 2, 2015
    Evokkimus , Jun 2, 2015 :
    Again, this google's bug, not Exodus.
    Btw, you seem to be on a slow connection, only 3g, that is most likely the cause for Mobile radio active bug
    akulata likes this.
  3. emilus
    Cupcake Jun 2, 2015
    emilus , Jun 2, 2015 :
    Hello, I still have problem with profiles :-( In 5.0 profiles was unstable, mean that after setup my own profiles it disappear. Today (5.1) I spend half hour to setup my profiles, but after restart everything gone :-(
    Is any possibility to fix this feature?
  4. Henry80
    Yep, I know. :(
    Do you know what's the only ROM I've recently used that hasn't got this annoying bug?
    A KitKat based ROM :(
    Jokes aside, in every Lollipop ROM I've used there has always been that bug: 5.0.2 or 5.1.1, doesn't matter.
    It's KitKat or live with the bug at the moment.
    vcespon likes this.
  5. Funk Wizard
    Moderator Moderator Jun 2, 2015
  6. JackScagnetti
    JackScagnetti , Jun 2, 2015 :
    I will wait till Friday to test this ROM hope all is worked out by then. I have high hopes! :D
  7. akulata
    akulata , Jun 2, 2015 :
    İ understand and i know bug is google..but just i said continue issue..
    (Sorry bad english ) :)
  8. Enyalius
    Jelly Bean Jun 2, 2015
    Enyalius , Jun 2, 2015 :
    @raja.m where did the show ram usage in recent menu go? Currently its saying that it "couldn't add widget" :(
  9. vcespon
    Gingerbread Jun 2, 2015
    vcespon , Jun 2, 2015 :
    Thank you for confirming this. I still see Google Play services and Android System at the top of battery ussage list. The phone has been actively used, more than 2 hours of screen on, and the screen takes half the power of Google Play services. So every Android 5.x ROM has the same problem for the moment.
    akulata likes this.
  10. return.of.octobot
  11. Henry80
    You're welcome: see also screenshots in this post.
    The only "fixes" I've found are:
    1. only use wi-fi and disconnect mobile data (it's not always possible, especially here in ITA)
    2. go back to KitKat
    If you are on Lollipop and you are using mobile data, the bug is gonna be there unfortunately.
    P.S: someone wrote the bug is there also in the Android M dev preview.
    akulata likes this.
  12. ngocmyan2525
    Cupcake Jun 2, 2015
  13. dustbunnyck
    dustbunnyck , Jun 2, 2015 :
    You guys should make software for the entire world. If everything ran as nice as Exodus then we would be so far ahead as a species
  14. Elas
    Elas , Jun 2, 2015 :
    Which are the Best gapps tout flash with the 5.1? PA Gapps caused me a lot of errors in in thé 5.0.2 so i'm looking to change... Zéro package would be appreciated
  15. AndrewM31
    Eclair Jun 2, 2015
    AndrewM31 , Jun 2, 2015 :
    i click on the download link but get a error page can somebody send me a link from mega or some cloud storage
  16. Antoine Vdb
    KitKat Jun 2, 2015
    Antoine Vdb , Jun 2, 2015 :
    Wiped the data thing (always thought it was deleting all my google data but seems gone now) thanks !
  17. RoberRamos
    Eclair Jun 2, 2015
    RoberRamos , Jun 2, 2015 :
    No, I mean I could draw a gesture to unlock the phone, just like a pattern
  18. Antoine Vdb
    KitKat Jun 2, 2015
    A French guy here :p
    Evokkimus and Elas like this.
  19. Farazahmed7
  20. Vshainky08
    Donut Jun 2, 2015
    Vshainky08 , Jun 2, 2015 :
    Is the battery drain becoz of new touch screen driver there? This is the only thing which is stopping me from flashing :(
