255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. gurjisolo
    Gingerbread Jun 12, 2015
    gurjisolo , Jun 12, 2015 :
    Getting a problem when using the on screen buttons my physical back button is still working , but only the back button ? Weird .
  2. ParamK.
    Moderator Moderator Jun 12, 2015
    ParamK. , Jun 12, 2015 :
    Just leave it Like that. if anything is different you will probably notice it
    Yes
    BramVanroy likes this.
  3. BramVanroy
    Eclair Jun 12, 2015
    BramVanroy , Jun 12, 2015 :
    Settings > Rom Controls > Check for updates
  4. P.S.@
    Honeycomb Jun 12, 2015
    P.S.@ , Jun 12, 2015 :
    not needed just dirty flash rom ;)
  5. avinashadvani
    Jelly Bean Jun 12, 2015
    avinashadvani , Jun 12, 2015 :
    I think the proximity sensor doesn't work very well in pocket, phone wakes itself up and does random things, today it dialed few friends on long distance damn...
    Lots of things get turned on and off on the notification drop down. I even removed the flashlight tile as that would drain battery and make the phone hot.
    Anybody else with this issue.
    I'm on latest 12 June build, been updating regularly.
    tim31 likes this.
  6. nordom
    Froyo Jun 12, 2015
    nordom , Jun 12, 2015 :
    Maybe add a PIN or pattern to unlock?
    I have 'double tap to wake' on and 'prevent accidental wake-up'(something like this) off, but I haven't noticed any issue. At least not that I know of.
    avinashadvani likes this.
  7. penndavid
  8. wmka2000
    Eclair Jun 12, 2015
    wmka2000 , Jun 12, 2015 :
    Why Cyanogen firmware in OP just 31 MB size, it should to be bigger size or I missed something?
  9. LastLeg
  10. penndavid
    LastLeg likes this.
  11. resporival
  12. avinashadvani
    Don't like h having a pin as I use the phone a lot.
    I didn't have this problem before on 502 and the kit kat ROM.
    Quite a bummer this
  13. TheFriki
    TheFriki , Jun 12, 2015 :
    I would strongly suggest a Volume botton on the quick settings menu where you can change volume of everything and/or vibration like the one in the original CM11s
  14. rhn345
  15. nordom
    Froyo Jun 12, 2015
    Yeah initially I didn't want that pin or pattern as well; but that's required to get wifi from where I work, for network credential or whatever. So I added a pattern as that's easier than a pin. Just one extra swipe.
    But you can also add a trusted face or voice under smart lock. That way the phone recognizes it's you and won't ask for the pin or pattern.
    I've not played with voice but trusted face works fairly well; it's quick and responsive. Yet lighting condition can be hard. For example under bright sunlight your face may appear too dark in the image and, well, you'll be asked for a pin.
  16. uvanils
    Cupcake Jun 12, 2015
    uvanils , Jun 12, 2015 :
    hi,
    i am getting below error while flashing the rom..
    Error executing updater binary
    any solutions?
  17. rhn345
  18. ashishjena
    ashishjena , Jun 12, 2015 :
    OLX pe bhech de .:p Call tec support,it seems you messed up with your phone.It seems your battery is dead .
  19. rhn345
    rhn345 , Jun 12, 2015 :
    ab toh yehi karna padega
  20. jomb3
    Eclair Jun 12, 2015
    jomb3 , Jun 12, 2015 :
    I noticed too that the proximity sensor didn't work properly because I could douple tap to wake even when the proximity sensor was covered. So I went to the settings, disabled and enabled acidental wakeup and tadaa, my phone was complete again! Maybe you should do the same...
