255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. arvindautar
    Eclair Jul 30, 2015
    arvindautar , Jul 30, 2015 :
    Exodus team beliefs that individual rights are not subject to public vote and should be decided collectively by themselves and no other. They belief that if you do not agree with them you are a ********* that steals basically.
    http://forum.xda-developers.com/one...m-kernel-unofficial-cyanogenmod-12-1-t3120259
    you can disable ads using https://f-droid.org/repository/browse/?fdid=org.adaway ( it is more uptodate than in exodus anyway )
    Seemodasupreemo likes this.
  2. avinashadvani
    Jelly Bean Jul 30, 2015
    avinashadvani , Jul 30, 2015 :
    Follow the herd or try the exodus ROM and see if it suits you and works well for you.
    For me it's perfect
  3. Seemodasupreemo
    Gingerbread Jul 30, 2015
    Seemodasupreemo , Jul 30, 2015 :
    I clearly said that in my comment that I was running Exodus.
  4. Dr. Indest
    Lollipop Jul 30, 2015
    Dr. Indest , Jul 30, 2015 :
    They got PO that I made the IgM flashable fix. That is their problem lol.
    JayminVyas likes this.
  5. avinashadvani
    OK sorry, I meant if you like it the way it's running then you can stay with it.:)
    It's been rock solid for me for months. I have tried all other ROMs and exodus is my go to ROM.
  6. Evokkimus
    KitKat Jul 30, 2015
    Evokkimus , Jul 30, 2015 :
    Do you have sunlight option on?
  7. Shadow1143
  8. darshandagly
    Froyo Jul 30, 2015
    darshandagly , Jul 30, 2015 :
    Can somebody help Me.
    I used the morph mode and switched to cyanogenmod UI, now how do I go back to exodus UI?
  9. markbrak
    Donut Jul 30, 2015
    markbrak , Jul 30, 2015 :
    Unlocked, rooted, and flashed my first Android last night. Seems to be running well so far. Thanks for the rom.
    RajaMu likes this.
  10. Evokkimus
    KitKat Jul 30, 2015
    Hmm, strange, my screen doesn't do this. I honestly am not sure what's going on.
  11. Shadow1143
    Shadow1143 , Jul 30, 2015 :
    Fixed, i changed screen color blue to 98% and now its normal and screen colors doesnt change.
    RajaMu, Evokkimus and avinashadvani like this.
  12. RajaMu
    RajaMu , Jul 30, 2015 :
    Goto developer options by 7 taps on build number then developer options enables then u can morph to exodus mode or aosp mode :)
    nusantara, Ramesh1249, P.S.@ and 3 others like this.
  13. sampoman
    Eclair Jul 30, 2015
  14. Marcoziezo
    Honeycomb Jul 30, 2015
  15. Marcoziezo
    JackScagnetti likes this.
  16. striker280
    Gingerbread Jul 31, 2015
    striker280 , Jul 31, 2015 :
    I'm running the first 5.1.1 build from june 2nd which is super stable but which build do you guys think is best to upgrade to in terms of stability, battery and features?
  17. avinashadvani
    Jelly Bean Jul 31, 2015
    avinashadvani , Jul 31, 2015 :
    22 build, if you not worried about the new anti piracy thingy then the latest 30 build is also rock solid
    Evokkimus and striker280 like this.
  18. vineetpratik
    vineetpratik , Jul 31, 2015 :
    will be jumping to cm nightlies , its seems 25th build is very stable and has got , same battery life as exo.. :)
  19. prannoytambe
    Froyo Jul 31, 2015
    prannoytambe , Jul 31, 2015 :
    Yea 25th build on official cm12.1 tends to have better than exodus, Exodus on standby till the issue gets resolved regarding the anti- piracy. Even the Sultan rom which is trending in comments is having some issues read recently some issue regarding camera and battery for last two builds keep an eye on that thread too.
    Rolodex likes this.
  20. Evokkimus
    KitKat Jul 31, 2015
    Evokkimus , Jul 31, 2015 :
    For me CM nightly just doesn't have that same smoothness as Exodus.
