255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. mykel_shoemaker
    Honeycomb Aug 14, 2015
    mykel_shoemaker , Aug 14, 2015 :
    the basic issue here, the developers got the ideas mixed up.They forgot the line.App protection is altogether a separate layer outside the operating system. I would support them ,if they brought it as an add on to their ROM and kept the base rom opensource,clean and neat.
    If we wanted a locked down ROM, we have IOS or other operating systems. If you see the against arguments in the last 100+ pages, you will see that most of the people are genuine, non-piracy supporting crowd. No one wants a big brother protection about virus,malware etc. This is like, if you want this rom, you need to use this inbuilt antivirus tool and adding a program blocking some content.
    Debate about what is malware , is totally another debate. But as everyone pointed out here, any destructive product should have a clear warning, TOS or other things, so that a user is aware. They told many of us that first post will reflect these add-ons soon.But till now, there is nothing in first post clearly outlining new restrictions on this rom.
    I hope developers take the discussion as a positive feedback from user community, than treating everyone as a thief or pirate.
    bakerbarber, Enamak, red5pade and 2 others like this.
  2. raiashu92
    Gingerbread Aug 14, 2015
  3. RajaMu
    Jelly Bean Aug 14, 2015
    RajaMu , Aug 14, 2015 :
    Great to hear thanks for your support :) yes we will focus more on best ROM ... @PrimeDirective making so many changes ..stay tuned
    Rolodex, red5pade and nusantara like this.
  4. wildf1re
    Ice Cream Sandwich Aug 14, 2015
    wildf1re , Aug 14, 2015 :
    Bump for support?
  5. raiashu92
    raiashu92 , Aug 14, 2015 :
    No such problem in 1108 build. Working fine. Though SOT has reduced from before, getting only 4 hrs on moderate usage.
  6. mykel_shoemaker
    Looks like an ad program or best of android type suggestion program working on background.
    Try lookout adware cleaning tool.
  7. RajaMu
    Thanks for your time and bringing to our notice ...
    We have already fixed and it will be addressed in next build let me know if you want my local test build I can share ! So that this issue can be avoided ..and also later update can be done using exodus updater :)
    Hi, we are already aware of this issue
    Rolodex likes this.
  8. zingchar
    Eclair Aug 14, 2015
    zingchar , Aug 14, 2015 :
    Guess i am invisible here hmmmm.........
  9. RajaMu
    Do you like to use test build its amazing backup and working very smooth..
  10. RajaMu
    Auto rotation working perfectly bro where is the exact problem
  11. mykel_shoemaker
    No problems with Gyroscope or autorotation on CM12.1 nightlies or Exodus (2107) versions, which I use. Since you have this problem in all ROMs, may be something wrong with your device side.
    Try clean factory reset/full wipe fresh install method.
  12. zingchar
    Eclair Aug 14, 2015
    Thanks for your reply.....doesnt work with any videos I am watching if i change to landscape or portrait...with auto rotation on. Also in any games...real racing 3/f18 carrier landing...i can't control the plane as the gyroscope not working. I just installed CPU Z...the sensors seem to be working in it. So I am confused as to why is doesn't work in apps or games.
  13. zingchar
    Eclair Aug 14, 2015
    okies will do a fresh clean wipe and install and update on here.....thanks for ur reply :)
  14. RajaMu
    No hold on let build come out 13th build still have issue
  15. RajaMu
    For people facing with FCs please take my local test build dirty flash will work ...
    And also u can later update via using exodus updater
    Please note this is test build please take your own risk and install mostly it won't trouble u
    http://1drv.ms/1LhG8BE
    Rolodex likes this.
  16. Aranu
    Eclair Aug 14, 2015
    Aranu , Aug 14, 2015 :
    Hello friends!
    Been using Exodus for a long time now!
    Plz i just got home from vocations and i would like to know which build currently the most effective in terms of battery consumption. Fyi i am on 17/7 build :) Thanks in advance!
  17. zingchar
    Eclair Aug 14, 2015
    Hmmm okies....i will go back to 11s stock for now ...will wait for the new build
  18. RajaMu
    You can dirty flash my build and let me know if u like it...
  19. parasaviator
    parasaviator , Aug 14, 2015 :
    bro care to share with me... im free to test today whole day...its been a while with gr8 battery backup on stock exodus
  20. girishb86
    girishb86 , Aug 14, 2015 :
    Okay, I'll bite. Downloading the 08/14 build right now. Hope I don't run into any issues.
    *fingers crossed*
