255
ROM [5.1.1_r24][Official][OTA] Exodus Android Lollipop
  1. girishb86
    Honeycomb Aug 14, 2015
    girishb86 , Aug 14, 2015 :
    Here you go;
    RajaMu likes this.
  2. avinashadvani
    Jelly Bean Aug 14, 2015
    avinashadvani , Aug 14, 2015 :
    latest builds really gone wonky!! i will hold off updating till i see positive feedback. sigh! @girishb86 let me know how the 14th works out for you.
    girishb86 likes this.
  3. yezi745
    Eclair Aug 14, 2015
    yezi745 , Aug 14, 2015 :
    than
    thanks for your reply, buddy. I do like this ROM very much, hope this ROM will be better and better.
  4. girishb86
    RajaMu likes this.
  5. raiashu92
    Gingerbread Aug 14, 2015
    raiashu92 , Aug 14, 2015 :
    No, i would rather use the normal nightlies :p , as i dont have any backup phones.
  6. RajaMu
    RajaMu , Aug 14, 2015 :
    U can flash dirty with regular nightly no need to worry of data loss :p
  7. Marcoziezo
    Marcoziezo , Aug 14, 2015 :
    What is different with your test build and the normal builds? :)
  8. RajaMu
    Fingers crossed .. Please update Something
  9. girishb86
    Rejoice! No FC issues in the latest nightly. Checked every single option in Settings.
    avinashadvani, Marcoziezo and RajaMu like this.
  10. RajaMu
    Its my local build and that is from.server build mine got some extra features where servers may not be having those changes
    avinashadvani and Marcoziezo like this.
  11. RajaMu
    Check recent app section and overview settings in interface
  12. girishb86
    All fine here. No FCs whatsoever.
  13. RajaMu
    @Abinashadvani we have fixed and regret for inconvenience ... We are planning for good changes just stay tuned hope you like exodus more than ever before
    avinashadvani and Rolodex like this.
  14. raiashu92
    Okay, will try.
    But lately the android system drain has increased. in 2407 build i was able to get 5+ hrs of SOT but now its at best 4hrs. Why so?
  15. RajaMu
    Latest addressed I believe .. For me 30% gave 2.30 hrs sot avg :)
  16. RajaMu
    Bro try this section and see does it shows up and the look n feel
  17. pritambhadane
  18. zingchar
    Eclair Aug 14, 2015
  19. pritambhadane
    pritambhadane , Aug 14, 2015 :
    how is that possible 20% and 2:30 SOT avg which build r u using i get max 4:20 hrs from 0-100% on 09.08.15 bulid
  20. RajaMu
    There are apps following lollipop design it may impact if we do so ... Technically not a good design to make it transparent and not a easy one @PrimeDirective can you have a look on this once if by any chance
