12
ROM [5.1.X]SlimSaber[SlimLP Unofficial Builds].
  1. werty2445
    Honeycomb Sep 20, 2015
    werty2445 , Sep 20, 2015 :
    Thanks,though I would like it if I didn't have to sacrifice the Bluetooth for it
  2. bongobanana
    Eclair Sep 20, 2015
  3. Shadow1143
    Gingerbread Sep 21, 2015
    Shadow1143 , Sep 21, 2015 :
    Anyone knows, how i can open supersu app? I flashed it to system. But cant find that app, when i go with google plays there are no open button.
  4. JayminVyas
    Ice Cream Sandwich Sep 21, 2015
    JayminVyas , Sep 21, 2015 :
    It should be there under Advanced Settings or something like that......which is under Settings, towards the lower end as you scroll down.
  5. Chromer19
    Honeycomb Sep 21, 2015
    Chromer19 , Sep 21, 2015 :
    We don't maintain the Xposed as we feel is may break the rom and cause bigger issues as the optimizations we have in our rom cause issues when working together.
    bongobanana likes this.
  6. Chromer19
    be forwarned that if you download and update the rom that you will use CameraMod, wait for the fix to be pushed out.
  7. d9975509777
    Honeycomb Sep 26, 2015
    d9975509777 , Sep 26, 2015 :
    I have flashed slim Saber 5.1.1 20150725 yesterday and since then my camera flash is not working.
    Can anyone help me out.??
    Tried searching for the solution in xda also be failed..
  8. Chromer19
    Honeycomb Oct 1, 2015
  9. vcespon
    Gingerbread Oct 14, 2015
    vcespon , Oct 14, 2015 :
    7 hours screen-on time with SlimSaber Bacon and Boeffla kernel. !!!
    Hi, after trying many Android Lollipop ROMs and a few kernel variants I have found that this one behaves like a kitkat ROM. Completly flat line when screen off and getting 7 hours SOT easily.
    This is after almost two days of moderate ussage. I spent about 2 hours whatching videos and 5 hours reading and browsing the web. And it still had 8% left after more than 7 hours screen on.
    lordofless and JayminVyas like this.
  10. Shadow1143
    Gingerbread Oct 15, 2015
    Shadow1143 , Oct 15, 2015 :
    Do i need to reflash SuperSU if i update this rom to newer version?
    Do i need wipe something?
  11. y0ngc6
    Cupcake Oct 17, 2015
  12. cogli0ne
    Gingerbread Nov 13, 2015
    cogli0ne , Nov 13, 2015 :
    Went from 0921 to 1111 today, noticed that many embedded videos in chrome freezes up (like on Facebook, i don't use the Facebook app) and sometimes plays without audio.
    I thought it had something to do with chrome and cleared cache and data for chrome but it didn't help.
    Flashed 1104 and tried the same things, problem still there. Cleared cache and data again, still problems.
    Flashed 0921. Everything works fine.
    Anyone else with the same problem?
  13. Evokkimus
    KitKat Nov 30, 2015
    Evokkimus , Nov 30, 2015 :
    @Chromer19 will you be creating a new thread for SlimSaber 6.0? Flashed it and would like a thread for it here :D
    You're not Fusionjack are you?
    yash9060 likes this.
  14. theshinybeast
    Marshmallow Nov 30, 2015
    theshinybeast , Nov 30, 2015 :
    No, he's not fusionjack but I'm with you on having a thread for SlimSaber 6.0.I'll be sticking with it for a while.:D
    yash9060 and Evokkimus like this.
  15. yash9060
    Honeycomb Dec 1, 2015
    yash9060 , Dec 1, 2015 :
    +1for new thread
    but now the sources are omni & I would love slim sources more than omni though both are built on aosp
    theshinybeast and Evokkimus like this.
  16. Evokkimus
    KitKat Dec 1, 2015
    Evokkimus , Dec 1, 2015 :
    I'm not sure about the sources' differences but I would like some more features to this ROM, like status bar and nav bar/nav buttons customization. Otherwise the ROM is really clean and I like it more than CM based ROMs.
    theshinybeast and yash9060 like this.
  17. theshinybeast
    Marshmallow Dec 1, 2015
    theshinybeast , Dec 1, 2015 :
    I tried out Radioactive Kernel with SlimSaber6.0 this morning it worked well but sadly it inverts the camera image so the image in the viewfinder is upside down .A damned pity because Synapse worked on it :(
  18. Psk.it
    KitKat Dec 1, 2015
    Psk.it , Dec 1, 2015 :
    since Slim v6 comes from Omni rom, you can try only "Donkey One" there is a link in my signature
    it is the only one that re-rotate the camera up-side-up :D
    otherwise the stock one by herma
    in my opinion Lightning is the better at the moment, but you have to migrate to broken (together them are really impressive... you will feeling like driving a ferrari after a fca 500L) :D :D (facciamoci riconoscere!!!) ;)
    since you are on AOSP v6, here you can find a useful package, talked about here
    are you brave enough? :D :D
    theshinybeast likes this.
  19. auerbach
    auerbach , Dec 1, 2015 :
    which gapps compatible with brokenos ?
    tried slim and open gapps but always get FC setting after booting !!
  20. Psk.it
    KitKat Dec 1, 2015
    i don't remember exactly, tipically i flash Open (link in my signature)
    try a clean flash, and / or check the broken thread
