2
5g in Switzerland
  1. olkitu
    Froyo Jun 10, 2020
    olkitu , Jun 10, 2020 :
    Yes 5G logo may seen because network send UpperLayerIndicator message. NOT RESTRICTED mean you don't have NR connection - because there is no 5G NR. You have to go closer 5G NR tower to get signal.
  2. jhoon_09
    Gingerbread Jun 10, 2020
    jhoon_09 , via OnePlus 8 , Jun 10, 2020 :
    Sorry for the late reply.
    If it showing 5G icon , it means you have 5G but the signal is very week to connect to it.
    try to use your phone outdoor or in different location.
    i am sure it will work.
  3. jhoon_09
  4. jhoon_09
    Gingerbread Jun 11, 2020
    jhoon_09 , Jun 11, 2020 :
    Hello,
    If your OnePlus 8 pro , OnePlus 8 or Oneplus 7T pro 5G is not connecting to 5G in 5G covered area .
    # Use single 5G SIM card in number 1 slot.
    Follow the steps here :
    Requirements:
    1- install EngineerMode apk manually on your phone: http://www.mediafire.com/file/i72tnya1aawo09v/Engineeringmode_V1.01.0.apk/file
    2- On you computer you need to have OnePlus driver installed:
    http://www.mediafire.com/file/zkua1ob0dzaor09/OnePlus_USB_Driver_Setup.exe/file
    3- QPST-application. Please find application from internet:
    http://www.mediafire.com/file/ocpqez9whauy5w6/QPST_2.7.474.zip/file
    4- The two XML files with enabled 5G network: http://www.mediafire.com/file/go0qava73eiz0m6/Carrier_Policy.zip/file
    5- USB-cable between your computer and phone.
    When you finish and ready:
    1- On phone you have to dial to *#801# and enable Rndis, diag switch. Don’t enable Serial-interface if you have installed apk manually.
    2- Connect your phone to your computer via USB.
    3- Open then QPST-application.
    4- On the menu Open Start Clients then QPST EFS Explorerand wait until you see the files.
    5- Then go to policyman.
    6- In the policyman - right list, you will see two file : carrier_policy.xml and carrier_policy.xml_Subscription01. Copy them to your computer as a backup if you need them in the feature.
    7- Now delete the two files (carrier_policy.xml and carrier_policy.xml_Subscription01) files from the policyman - right list.
    8- Now go to the tow XML files you already download earlier – 5G enabled network. Copy them to the policymandirectory , drop and drag one each time.
    9- Reboot your phone , your 5G is enabled now.
    On OnePlus 8 and 8 Pro you may have to enable 5G NR via *#*#4636#*#* then Phone Information -> Set preferred network type. Choose :
    NR/LTE/TDSCDMA/CDMA/EvDo/GSM/WCDMA
    Or
    NR/LTE/TDSCDMA/GSM/WCDMA
    Enjoy the 5G speed :hearteyes::hearteyecat:
    Very Big Thanks to::sunglasses::sunglasses:
    1- Mr. Minh Truong:
    https://mt-tech.fi/en/modify-oneplus-7-pro-5g-8-and-8-pro-nr-lte-a-band-combos/
    2- Mr. Abdullah Alshehri :
    https://twitter.com/AdAlShehri737
    3- Mr. Mussab Alghamdi :
    https://twitter.com/MussabAlghamdi
  5. S1587490215110
    Eclair Aug 25, 2020
    S1587490215110 , Aug 25, 2020 :
    hei there
    Any reason my phone is not showing up in the QPST application? I did every step. I also checked if my qualcom drivers were installed and they are. The phone is showing in the devices on windows but not in the application, any ideas?
  6. orphanos.y
    Cupcake Aug 31, 2020
    orphanos.y , Aug 31, 2020 :
    Hi @S1587490215110,
    I had the same issue and fixed it by checking which COM was in use on my computer. Then I specified it in QPST in order to make it working.
  7. R1602192391024
    Cupcake Oct 8, 2020
    R1602192391024 , Oct 8, 2020 :
    Hi, did you manage to figure this out? I have the same issue (also Swisscom).
    pajarito32 likes this.
  8. #28
  9. R1602192391024
    Cupcake Oct 11, 2020
    R1602192391024 , Oct 11, 2020 :
    Thanks for replying. Did you need to do anything in particular? I upgraded tonight but still do not have 5g service (and yes I am in an area with 5g coverage).
  10. olkitu
    Froyo Oct 11, 2020
  11. hadid90
    hadid90 , Oct 11, 2020 :
    this is not working on OOS 11 :(
  12. olkitu
    Froyo Oct 11, 2020
  13. hadid90
  14. hadid90
    Cupcake Oct 12, 2020
  15. olkitu
    Froyo Oct 12, 2020
    olkitu , Oct 12, 2020 :
    You enabled Engineer Mode instead of Diag,rndis on *#800# menu?
  16. hadid90
  17. R1602192391024
    Cupcake Nov 14, 2020
    hadid90 likes this.
  18. olkitu
    Froyo Nov 15, 2020
    #38
  19. hadid90
    Cupcake Nov 15, 2020
    hadid90 , Nov 15, 2020 :
    I am following that tutorial .. except for the driver part .. the xperia drivers shows a list of hundreds of drivers .. which one to choose for op8 ?????
    #39
  20. hadid90
    finally after so much looking around i found my answer
    it s
    qualcomm HS-USB diagnostics 9091 !!
    #40
