5g Not supported for OP9 series in UAE via OnePlus 9
  1. Shamsheer.babu26
    Cupcake Oct 24, 2021
    Shamsheer.babu26 , via OnePlus 9 , Oct 24, 2021 :
    I have OP 9 5g but it's note supported or showing as 5g phone in UAE, only LTE working. Then what is use of 5g in OP 9series..🙄
    I used other 5g brand smartphone but those working and showing 5g network on the display 😊
  2. hbk1402
    KitKat Oct 24, 2021
    Shailender Sharma likes this.
  3. pablofg1978
    Head Moderator Head Moderator Oct 24, 2021
    pablofg1978 , Oct 24, 2021 :
    First you need to check if your phone supports the 5g band that your carrier uses.
    Then you need to ask to your carrier to add 5g support for your device model.
    In order to work on 5g your device needs to be certified by your carrier.
    Caomhin and Shailender Sharma like this.
  4. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Oct 24, 2021
    Nipu_1998 , via OnePlus 9 Pro , Oct 24, 2021 :
    Did you brought the Device from India? The Indian variant supports only the n78 band and check with your carrier supported bands to confirm whether the band is supported
    Also some carriers need to whitelist the device for 5g support.
    Either of the two can be a reason.
    Shamsheer.babu26 and Caomhin like this.
  5. Gamingtime1121
    Honeycomb Oct 26, 2021
    Gamingtime1121 , via OnePlus 9 , Oct 26, 2021 :
    This question was asked before. In Middle East Oneplus 5g doesn't work as far as i know and it should be mentioned on the site where you purchased the phone from.
  6. hbk1402
    KitKat Oct 26, 2021
    hbk1402 , Oct 26, 2021 :
    Awaiting your reply
  7. Shamsheer.babu26
    Cupcake Oct 29, 2021
    Shamsheer.babu26 , via OnePlus 9 , Oct 29, 2021 :
    Yes bought from UAE.. Using Etisalat but My OP doesn't have 5G option in Network setting
  8. Shamsheer.babu26
    Thanks your replays.. Appreciate
  9. N1634471408842
    Donut Nov 1, 2021
