5ghz wifi band issue on op6
  1. Akib___Hossain
    Cupcake Jan 30, 2020
    Akib___Hossain , Jan 30, 2020 :
    currently I am using mi router 4A dual band version but on my OnePlus 6, 5ghz is not showing where as other devices on my house is showing and connected to 5ghz band an anyone give the solution of it?
  2. Kytharsis
    Marshmallow Jan 30, 2020
    Kytharsis , Jan 30, 2020 :
    How close are you to the router and do you NEED 5 GHz?
    Caomhin, drl431 and Akib___Hossain like this.
  3. Akib___Hossain
    i am right beside the router and the matter is not weather i need or not!, matter is why can't i find it!
  4. Kytharsis
    Check the router settings.
    Caomhin likes this.
  5. Caomhin
    KitKat Jan 31, 2020
    Caomhin , via OnePlus 6T , Jan 31, 2020 :
    You can also try resetting the WiFi,
    Settings, System, Reset Options, Reset WiFi
    Kytharsis and drl431 like this.
  6. gutomore
    Cupcake Feb 12, 2020
    SHAWON GN and SanchitKumar28 like this.
  7. Caomhin
    KitKat Feb 12, 2020
    Caomhin , via OnePlus 6T , Feb 12, 2020 :
    Have you tried to reset WiFi as mentioned in the post above yours?
    DrJMun likes this.
  8. krishnanvish
    Cupcake Feb 15, 2020
  9. Kytharsis
    Marshmallow Feb 15, 2020
    Kytharsis , Feb 15, 2020 :
    Pretty sure this won't affect casting.
    Caomhin likes this.
  10. Caomhin
    KitKat Feb 15, 2020
    Caomhin , via OnePlus 6T , Feb 15, 2020 :
    Open Cast, click the 3 dot menu, select Enable Wireless Display.
  11. krishnanvish
  12. Caomhin
    KitKat Feb 15, 2020
    I notice you said 5ghz network, does it work on the 2.4ghz which is available on the router as well?
  13. krishnanvish
  14. Caomhin
    KitKat Feb 15, 2020
    In order to see is it the phone or the WiFi, just need to check if its working on the 2.4ghz network but not on the 5ghz,its logical troubleshooting to identify the issue.
    Does it work on 2.4ghz?
  15. krishnanvish
  16. krishnanvish
  17. Caomhin
    KitKat Feb 15, 2020
    Try reset your WiFi on the phone.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    See if that helps
  18. krishnanvish
  19. Caomhin
    KitKat Feb 15, 2020
  20. krishnanvish
