[Answered] 5GHz WiFi connection issues depending on legacy mode setting of router
  1. J1548693491916
    Cupcake Jan 29, 2019
    J1548693491916 , Jan 29, 2019 :
    On Router create seperate SSID for 2.4 an 5 GHz WiFi
    Set 5GHz WiFi to n/ac mixed mode
    Try to connect
    Does not work with my Router Compal CH7467CE
    Mode a/n/ac works unstable
    Mode ac only works stable
  2. J1548693491916
    Cupcake Mar 4, 2019
  3. Z1554712853121
    Cupcake Apr 8, 2019
  4. W1566201484766
    Cupcake Aug 19, 2019
    W1566201484766 , Aug 19, 2019 :
    Connection issue of 5GHz based on OP6 WiFi Wireless setting. You can connect your wireless router via TP-link or any other router. go to your WIFi setting it shows only 2.4 GHz-> Then go to Additional Setting-> select your region-> Then disconnect and reconnect your wifi device it shows 5GHz wifi network automatically. Connect it and enjoy the service. If you failed further to connect your network then Read more to get full information.
