3
5ghz wifi issue via OnePlus 6 Amber Red
  1. Sarathbabu24 , via OnePlus 6 Amber Red , Oct 30, 2020 :
    Hi team,
    Have submit more log files nd have raised more thread regarding my issue stil unresolved more than a year
    I connect my mobile one plus 6 to 5ghz It connect perfectly without issue after an hour it disconnect nd reconnect automatically ths irritate me lot as I use to play games using 5ghz
    I reset my connectivity, reset my modem have different ssid stil I have issue please sort it out soon
  2. Caomhin
    Marshmallow Oct 30, 2020
  3. #3
  4. Caomhin
    Caomhin , via OnePlus 6T , Oct 30, 2020 :
    Hardware radios in different phones will be from different manufacturers, sometimes there can be variances in the hardware. Not all phones are the same, hence why you have different manufacturers.
    Some can be more or less sensitive than others, the info above is a suggestion to see if you can identify the issue. Entirely up to you if you wish to try it or not.
  5. #5
  6. Caomhin
    Marshmallow Oct 31, 2020
    Caomhin , via OnePlus 6T , Oct 31, 2020 :
    Also check the following
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
    If the suggestion there don't fix it. Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  7. #7
  8. Deepakdkp
    Honeycomb Nov 3, 2020
  9. #10
    Sarathbabu24 likes this.
  10. #11
  11. O. Priya
    Gingerbread Nov 10, 2020
