49
ROM [6.0.1_r22] Exodus Android - 6 for OnePlus One Bacon
  1. tfae
    Ice Cream Sandwich Apr 25, 2016
    tfae , Apr 25, 2016 :
    Change ROM.
    SeanMartin and akiles like this.
  2. akiles
    Froyo Apr 26, 2016
    akiles , Apr 26, 2016 :
    Pay developers for their hard work.
  3. strafer
    Lollipop Apr 26, 2016
    strafer , Apr 26, 2016 :
    Just switched with a clean install from CM13 to exodus. First I installed the version posted by Raja, after that I wasn't able to start dailer or contacts. Then I updated to 25042016, now I can start contacts (and dailing works) but cannot start dailer itself.
    Edit: Ok, dailer works now. Had to delete app data.
  4. RajaMu
    Jelly Bean Apr 26, 2016
    RajaMu , Apr 26, 2016 :
    Sorry , we cant support you on this ! :(
    PCesar.Cercal likes this.
  5. RajaMu
    be careful with backup restores ! infact contact syncs with gmail acc. try to use it !
    strafer likes this.
  6. RajaMu
    hey you can toggle these options from settings app and well remaining things kernel and rom will take care nothing to worry about. dont move out of stock which may impacts the performance & unnecessary issues
  7. strafer
    Many apps are starting with android, many of them don't need to (games etc.). In CM13 there was an option where I was able to disable start on boot for apps which was really a good thing.
    Is there same option in exodus somewhere? Cannot find it.
  8. Tom_2103
    Gingerbread Apr 27, 2016
  9. wordpass
    Gingerbread Apr 28, 2016
    wordpass , Apr 28, 2016 :
    snap camera is awesome! is it me or does anyone else find that the icons are bigger in 6.0?
  10. wordpass
  11. wordpass
    I think that is because of lack of grid size modification capability in Launcher3
  12. anujmjn
    Cupcake Apr 28, 2016
    anujmjn , Apr 28, 2016 :
    Is anyone experiencing slow charge problems on the 27th April build. I shifted to exodus from COS 13 for the same reason that on COS 13, the phone was charging extremely slow. Is it a bug on the ROM or something wrong with my phone. I experienced slow charge issues on Oxygen 2.1.4 as well.
  13. strafer
    Lollipop Apr 28, 2016
    strafer , Apr 28, 2016 :
    No problems here, must be your phone.
  14. anujmjn
    Any possible reason??
  15. strafer
    1. Cable / charger
    2. Charging electronic inside phone
    3. Battery itself
    RajaMu likes this.
  16. weltenbrand
  17. zapablast05
    Ice Cream Sandwich Apr 29, 2016
  18. Setting.out
    Gingerbread Apr 30, 2016
    Setting.out , Apr 30, 2016 :
    Say goodbye to getting new apps from XDA labs or other third party nonpirated apps that are not available through the play store. Content guards blindly blocks all apps that it deems unworthy.. This is bulls#!t.. This hurts developers and needs a major overhaul. Blocking pirated apps is fine, but not just downloaded apps in general.
    jstepa likes this.
  19. minecabla
    Honeycomb Apr 30, 2016
    minecabla , Apr 30, 2016 :
    You're incorrect. Thats google play services blocking the installation. I also use miXplorer and I got a similar pop-up saying that I should remove it. My pop-up had a dismiss button so I dismissed it. ContentGuard would simply remove it without asking.
    henkmeuter likes this.
  20. xfarsuperior
    Cupcake May 1, 2016
    xfarsuperior , May 1, 2016 :
    Click on more details and install anyway... No need to get mad lol
    minecabla likes this.
