6G or 8G? Please help choose
  1. bopang
    Cupcake Nov 27, 2017
    bopang , Nov 27, 2017 :
    Hi There,
    I am totally new to android and I would like to start from OnePlus 5T. I just wondering how much difference between 6G or 8G RAM? I occasionally do some gaming on my phone like 2k18, and mostly use some very basic apps.
    If I choose 6G RAM, do I need to close other apps before I run some large app? Or the OS can help me determine just like IOS?
    Thank you for the help!
  2. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Nov 27, 2017
    mojoyoyo77 , Nov 27, 2017 :
    Today 6 GB are more than enough, you will not have problems, in the future you never know. For me storage is more important, 128 GB is great.
    For the price difference there is, if you can afford it choose the 8 GB / 128 GB version
  3. Huigiebaby
    Ice Cream Sandwich Nov 27, 2017
    Huigiebaby , Nov 27, 2017 :
    The real choice is 64 vs 128GB, performance difference 6 vs 8GB RAM is barely noticeable.
  4. mcmpick
    Froyo Nov 27, 2017
  5. Onkar.Singh
    KitKat Nov 27, 2017
    Onkar.Singh , Nov 27, 2017 :
    Between 6 and 8 ... 6 is fine as well... however if you take storage into consideration then I would always suggest to go for 128 ... and that comes with 8 only ... :)
  6. GuitarBart
    Jelly Bean Nov 27, 2017
    GuitarBart , Nov 27, 2017 :
    For me it was only the storage. Coming from the One with 64 I wanted 128 so my choice fell on the 8gb model. There is no other difference
  7. ɢноѕтΘпе
    Nougat Nov 27, 2017
  8. Easwar_Sivaram
    Donut Nov 27, 2017
    Easwar_Sivaram , Nov 27, 2017 :
    Performance wise you would not notice much of a difference between the two versions. More than the RAM, the storage should be the deciding factor considering the fact that oneplus doesn't have a microSD slot.
  9. MentalDraco
    Marshmallow Nov 27, 2017
    MentalDraco , Nov 27, 2017 :
    as long as the 64 GB is nuff for you go for the 6 GB, i got the 128 with 8 GB so i can stash all my music
    ElfStone likes this.
  10. ElfStone
    ElfStone , Nov 27, 2017 :
    Like everyone said, storage is the only thing that matters, in this case.
    I went for the 6 / 64 version, as 64 GB is enough for me
  11. daddycool
    Gingerbread Nov 27, 2017
    daddycool , Nov 27, 2017 :
    I agree with others it's the storage you need to decide on. ram is not really relevant as both are plenty
  12. Søren Ravn Lund
