[6T][OOS11] Low performance via OnePlus 6T
  1. radfel
    Donut Oct 14, 2021
    radfel , via OnePlus 6T , Oct 14, 2021 :
    I recently upgraded my OOS from 10.x to 11.1.1 (I didn't receive a 11.0.x update for some reason). Now the whole system is very slow. Each application opens (sometimes much!) slower than it used to.
    Today I even noticed it using Android Auto, which used to work smoothly in my car.
    Sometimes it takes up to few seconds (!) for a button in a random app to react. I can see the tap happened, but the reaction for it is slow, like if suddenly there was not enough computing power on the device, which clearly isn't the case.
    What can I do to make the OOS 11 run fast on my OP 6T?
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 14, 2021
    Best Answer
    Artemus , Oct 14, 2021 :
    Back up your data and reset the phone. Remember to select "Start fresh" when prompted during setup and restore your data after setup has completed. This ensures old, corrupted data doesn't get reintroduced.
  3. radfel
    Donut Oct 15, 2021
    radfel , via OnePlus 6T , Oct 15, 2021 :
    You mean factory reset?
  4. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 15, 2021
  5. radfel
    Donut Oct 15, 2021
    I'm not a huge fan of the 'try format C' type of advices, but if this is what it takes to make my phone usable again, so be it.
    I'll try and post the result in here.
    Artemus likes this.
  6. radfel
    Donut Oct 16, 2021
    Artemus likes this.
  7. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 16, 2021
    radfel likes this.
