2
6T Screen brightness
  1. ordxpres
    Eclair Nov 13, 2018
    ordxpres , Nov 13, 2018 :
    So on day one I ordered OP6T. It's all nice except for the screen brightness. On my 5T I kept the brightness at around 25-30% and it was already bright.. On 6T I have to get the slider close to 90% in order to get a decent brightness. At 30% it's almost completely dark (useless in the daylight). Anyone experiencing this behavior? Is it normal or do I have a Lemmon that needs to be replaced?
  2. itzxmj
    Cupcake Nov 13, 2018
    itzxmj , Nov 13, 2018 :
    Maybe it will get better with the next update, yk it's a new phone
    Well for me I guess it's okay
  3. hiimanshh_
    Froyo Nov 13, 2018
  4. Richardp1108
    Richardp1108 , Nov 13, 2018 :
    I actually thought the screen on OnePlus 5 got too bright too quickly, where I almost never went past 40% brightness. I think this was perhaps a recalibration that went a bit too far.
    Personally, I prefer this since I keep my phone darker than most people.
    Roby72 likes this.
  5. AshenPaladin
    Froyo Nov 13, 2018
    AshenPaladin , Nov 13, 2018 :
    Isn't this just the new brightness algorithm introduced in Android Pie?
    As a 6 user, I noticed a big change in how the brightness worked in Oreo and in Pie, and there was a post by OnePlus explaining that.
    Basically the new algorithm tries to learn based on your usage, and that's why your mileage might vary until it learns.
    Roby72 and Richardp1108 like this.
  6. Neddard
    Lollipop Nov 13, 2018
    Neddard , Nov 13, 2018 :
    Check out this post by @dsmonteiro: https://forums.oneplus.com/threads/brightness-less-for-one-plus-6-t.935434/#post-19418847
    Hope it helps.
    dsmonteiro and TheMadKing like this.
  7. ordxpres
    Eclair Nov 13, 2018
    SanjeetChandra009 likes this.
  8. AshenPaladin
    Froyo Nov 13, 2018
  9. Neddard
  10. ordxpres
    Eclair Nov 13, 2018
    Thanks
    Can't say I'm happy about it. It's like going from one extreme to another. As long as I am not the only one, I guess I'll have to live with it. Hopefully it will not cause any screen burn-In
  11. admorris
    Froyo Nov 14, 2018
    admorris , Nov 14, 2018 :
    I think it's just Android Pie. The Essential Phone had same issue and everyone was claiming brightness was lowered, but in actuality the scale was just changed...maximum brightness stayed the same.
  12. ajarav
    Gingerbread Nov 20, 2018
  13. NikhilJagtap
    Ice Cream Sandwich Nov 20, 2018
    NikhilJagtap , Nov 20, 2018 :
    Many devices running on Pie are having brightness issue. My Nokia phone was brighter on Oreo ROM.
    Is it a problem with AOSP ROM?
  14. X1558871026247
    Cupcake Aug 9, 2019
    X1558871026247 , Aug 9, 2019 :
    It becomes real pain to use OP6T in direct sun bcoz it is way too difficult to see anything when u r out in direct sun. Getting irritated now bcoz of this drawback. The new updates too have nothing in it regarding this. Please look into this.
  15. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Aug 9, 2019
    Artemus , Aug 9, 2019 :
    Did you really need to bump this thread for something unrelated?
  16. X1558871026247
    Cupcake Aug 9, 2019
    i don't think i bumped in a wrong thread (read the title)
  17. Artemus
    Technically you did. The OP asks why the brightness slider is higher than in Oreo for the same amount of brightness (which was a major problem when Pie came around); yours is asking for them to up the brightness more due to direct sunlight. Also, you necroposted.
